03-07-2016, 08:02 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | qmobile format ? Operation : Check/Read Info [ v1.15 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 39 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Finish at : [3/7/2016 / 11:32:06 AM] Start at : [3/7/2016 / 11:32:09 AM] Operation : Check/Read Info [ v1.15 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00:00:15 Reconnect Power/Cable! Finish at : [3/7/2016 / 11:32:24 AM] |
03-07-2016, 08:17 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Select correct boot ( there is few one ) if you not want/not understand/or have own reason to NOT try do it - tick "reset in SVC" and do format again. |
03-07-2016, 09:18 | #6 (permalink) |
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | Reconnect Power/Cable! Finish at : [3/7/2016 / 12:49:14 PM] Start at : [3/7/2016 / 12:50:03 PM] Operation : Format File System / Reset Settings [ v1.15 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 38 ] Open Port Failed! Reconnect Power/Cable! Finish at : [3/7/2016 / 12:50:13 PM] Start at : [3/7/2016 / 12:50:29 PM] Operation : Format File System / Reset Settings [ v1.15 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 38 ] Open Port Failed! Reconnect Power/Cable! Finish at : [3/7/2016 / 12:50:32 PM] Start at : [3/7/2016 / 12:50:43 PM] Operation : Format File System / Reset Settings [ v1.15 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... Normal Mode init Sync... ========================= Start ========================= 3/7/2016 / 12:52:13 PM ================================================== ======= Card found: S/N : 533B1BFE , v0130 Chinese Miracle II [SPD module] v 1.15 Start at : [3/7/2016 / 12:53:03 PM] Operation : Format File System / Reset Settings [ v1.15 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... Normal Mode init Sync... ========================= Start ========================= 3/7/2016 / 12:54:35 PM ================================================== ======= Card found: S/N : 533B1BFE , v0130 Chinese Miracle II [SPD module] v 1.15 Start at : [3/7/2016 / 12:55:20 PM] Operation : Format File System / Reset Settings [ v1.15 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... Normal Mode init Sync... ========================= Start ========================= 3/7/2016 / 12:56:16 PM ================================================== ======= Card found: S/N : 533B1BFE , v0130 Chinese Miracle II [SPD module] v 1.15 Start at : [3/7/2016 / 1:02:26 PM] Operation : Format File System / Reset Settings [ v1.15 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... Normal Mode init Sync... |
