12-06-2019, 15:35 | #1 (permalink) |
Freak Poster Join Date: Feb 2018 Location: bahawalpur
Member: 2809413 Status: Offline Sonork: CharlesMaind Thanks Meter: 26 | qmobile g6 flash file 2019 NEOTEL61D_BU1_11C_PCB01_gprs_MT6261_S00.A608_QMOBI LE_G6_V27_180820 Card found : S/N : CEA8927D , v0138 Chinese Miracle II [MTK module] v 1.58 Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 26 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 25F9BBACC5B336F73D1F374B182BF4FA BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : No , Code : 7755 PLock|MobTrack : Not active Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 26 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 25F9BBACC5B336F73D1F374B182BF4FA BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : NEOTEL61D_BU1_11C_PCB01_gprs_MT6261_S00.A608_QMOBI LE_G6_V27_180820.bin FileVersion : A608_QMOBILE_G6_V27_180820 Saved to : C:\InfinityBox\CM2MTK\Read_out\NEOTEL61D_BU1_11C_P CB01_gprs_MT6261_S00.A608_QMOBILE_G6_V27_180820.bi n Done! Elapsed: 00:00:15 Reconnect Power/Cable! ...... update: password-protected link has been deleted please in future upload only password-free files Last edited by InfinityHelp; 12-07-2019 at 14:25. Reason: password-protected link has been deleted |
12-07-2019, 14:25 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
