Old 01-20-2020, 18:46   #1 (permalink)
Member: 1870226
Thanks Meter: 52
Qmobile HD Plus 8.1.0 SP9850KA Flash File Needed
PLZ can somone share qmobile HD plus sp9850ka flash file
Old 01-20-2020, 18:48   #2 (permalink)
Member: 1043909
Thanks Meter: 60,921
Do you know what is the estimated firmware version ?
Old 01-21-2020, 05:18   #3 (permalink)
Member: 1870226
Thanks Meter: 52
SP9850KA__QMobile__HD_Plus__8.1.0__QMobile_HD_Plus _MP_05_12__OPM2.171019.012__sp9850ka_1h10
Old 01-21-2020, 10:28   #4 (permalink)
Member: 1870226
Thanks Meter: 52
Any one have this flash file plz help ?
Old 01-22-2020, 12:32   #5 (permalink)
Member: 1043909
Dear Sirs,
If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool
Please do not upload password protected or damaged files, all of them will be deleted after upload.
Thank you !
Old 01-24-2020, 15:57   #6 (permalink)
Member: 1870226
Thanks Meter: 52
Operation : Read FW [ v2.04 ]
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC9850x_BASE : SC9850_eMMC_1GB_RS
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
Device info :
Patch Level : OPM2.171019.012
Display ID : QMobile HD Plus_MP_26_02
Ver. Incmt : 0225
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2019-02-05
Build Time : 1551179009
Product Model : HD Plus
Product Brand : QMobile
Product Name : QMobile_HD_Plus
Product Device : QMobile_HD_Plus
Product Manfct : QMobile
Product Info : sp9850ka_1h10
Product Board : sp9850ka_1h10
Board Platform : sp9850ka
AndroidVer : 8
VlnrLevel : 0x02
SP9850KA__QMobile__HD_Plus__8.1.0__QMobile_HD_Plus _MP_26_02__OPM2.171019.012__sp9850ka_1h10
Read : u-boot.bin
Read : sml.bin
Read : tos.bin
Read : vbmeta.img
Read : ldsp_l.bin
Read : gdsp_l.bin
Read : modem_l.bin
Read : pm_sys.bin
Read : nvitem_l.bin
Read : modem_wcn.img
Read : phase.cfg
Read : boot.img
Read : recovery.img
Make : persist.img
Read : boot_logo.bmp
Read : fastboot_logo.bmp
Read : dtbo.img
Read : system.img
ExtSparse : Compression ratio : 86%
Read : vendor.img
ExtSparse : Compression ratio : 52%
Make : userdata.img
Make : cache.img
Read : prodnv.img
ExtSparse : Compression ratio : 93%
Read : u-boot-spl.bin
Waiting for device ...
ADB : Device found!
ADB : Connected!
ADB : Prepare Ok!
Found bear!
Just some noise around. Wait ...
Thinking about the meaning of life ...
Firmware size : 0x94922324 ( 2.32 GiB )
Android Info saved : _Android_info.txt
Reconnect Power/Cable!
Done!
Elapsed: 00:51:41
The Following User Says Thank You to tokey786 For This Useful Post:
Old 01-24-2020, 15:59   #7 (permalink)
Member: 1870226
Thanks Meter: 52
Open : SPD_PROG.xml
Reading package ...
Read package finished!
Created by Infinity-Box (c) 2020
Chinese Miracle II : Spreadtrum / UniSoc Service Module
Device Info file : _Android_info.txt
Ver. Incmt : 0225
Ver. CodeName : REL
Operation : Flash Firmware [ v2.04 ]
Setting : Update NVRAM : False
Setting : Force NVRAM : False
Setting : Update PMT : True
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : INFINITY FW PACKAGE
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
PMTMng : Skip update! Reason : untested chain!
UBOOT : u-boot.bin
Failed to update block!
ERROR : 000000AC:AC000000FF537E00
GEN : UNKNOWN RESPONSE!
Error : Flashing failed!
Check previous message for more info!
Setting : Update PMT : False
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
UBOOT : u-boot.bin
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
UBOOT : u-boot.bin
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
ProtoEx : Forced FlashWrite enabled!
Boot Done!
UBOOT : u-boot.bin
UBOOT : u-boot.bin
CODE : sml.bin
CODE : sml.bin
CODE : tos.bin
CODE : tos.bin
CODE : vbmeta.img
CODE : vbmeta.img
CODE : ldsp_l.bin
CODE : gdsp_l.bin
CODE : modem_l.bin
CODE : pm_sys.bin
CODE : modem_wcn.img
ERASE : MISC
CODE : boot.img
CODE : recovery.img
FSIMG : persist.img
CODE : boot_logo.bmp
CODE : fastboot_logo.bmp
CODE : dtbo.img
FSIMG : system.img
FSIMG : vendor.img
FSIMG : userdata.img
FSIMG : cache.img
FSIMG : prodnv.img
ERASE : UBOOT_LOG
UBOOT : u-boot-spl.bin
Flashing finished!
Done!
Elapsed: 00:06:47
will upload file soon
The Following 2 Users Say Thank You to tokey786 For This Useful Post:
Old 01-24-2020, 17:05   #8 (permalink)
Member: 1870226
Thanks Meter: 52
Hd plus goes to menu but no soft keys and notification panel and dark wallpaper if lock screen with power button and wakeup blank screen nothing appears. After flash phone is in same condition. Didnt work for me maybe phone is having flash ic problem or am i doing some mistake while flashing ?
Old 01-24-2020, 18:48   #9 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
You can check it easy - enable same options in settings tab ( proto Ex should be also active )
Do format FS in wipe mode.
If at phone start it does not boot in recovery and not do wipe - eMMC problem, gone to read-only.
The Following User Says Thank You to JayDi For This Useful Post:
Old 01-25-2020, 08:01   #10 (permalink)
Member: 1870226
Thanks Meter: 52
After process done as you said. phone shows Erasing but problem still there blank screen after phone goes to sleep mode. any solution to this readed file was from working phone.
Old 01-25-2020, 08:16   #11 (permalink)
Member: 1870226
Thanks Meter: 52
Forced Wipe Phone Dead
Old 01-25-2020, 16:43   #12 (permalink)
Member: 1870226
Thanks Meter: 52
https://drive.google.com/open?id=1yE...YFue4FcTgcQQwL
Old 01-25-2020, 19:17   #13 (permalink)
sajidi1984's Avatar
Member: 2778467
Sonork: only Telegram
Thanks Meter: 265
this backup is from working phone or damaged phone ?????
Old 01-25-2020, 19:59   #14 (permalink)
Member: 1870226
Thanks Meter: 52
The Firmware uploaded From working Phone
Old 06-08-2020, 06:50   #15 (permalink)
Member: 1698141
Sonork: 1617901
Thanks Meter: 155
Qmobile HD Plus 8.1 Flash file free
FREE FLASH FILE DOWNLOAD
PASSWORD paidfile
Last edited by InfinitySupport; 06-28-2020 at 08:34. Reason: link to password protected file removed
Page generated in 0.23111 seconds with 9 queries
