08-12-2017, 09:06 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Rawalpindi Pakistan Age: 37
Member: 541180 Status: Offline Sonork: 100.1626680 Thanks Meter: 147 | Qmobile i7i Firmware Write Failed. Qmobile i7i Format Done By CM2 Code: Set mode to : [AltLDR] SP [SC773x] eMMC [Android 5.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 96 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v4 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000180000000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:46 Reconnect Power/Cable! Qmobile i7i Firmware Write failedDone By CM2 Code: Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : QMobile_i7i_MP_31_10.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : QMobile_i7i_MP_29_10 File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : LOGO.bmp File : charge.bmp File : prodnv.img File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 96 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac Boot failed! Boot failed! Reconnect Power/Cable! only this problem i face with i7i other spd phone read write format etc ok. any body tell me how can i fix this? |
