04-04-2018, 14:09 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Qmobile K650 SPD 6531 Not supported Phone found! [ 204 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot didn't start! Check model selection! Boot Error! Break Reconnect Power/Cable! Problem = Security Code |
04-04-2018, 14:19 | #2 (permalink) |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Solved Card found : CEE6926A , v0136 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.02 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR Operation : Read UserCode [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL NOT started! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! SPRD mode : SC6531 : REV : 0000 : NOR Operation : Read UserCode [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL NOT started! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! SPRD mode : SC6531 : REV : A000 : NOR Operation : Format FileSystem [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL NOT started! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! SPRD mode : SC6531 : REV : C000 : NOR Operation : Format FileSystem [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL NOT started! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! SPRD mode : SC6531 : REV : E000 : NOR Operation : Format FileSystem [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0E9 9E455C67D_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
The Following User Says Thank You to Aamir_Zia For This Useful Post: |
04-04-2018, 15:01 | #3 (permalink) |
Freak Poster Join Date: Sep 2009 Location: LodhranPakistan Age: 43
Member: 1117638 Status: Offline Sonork: G_ABBAS Thanks Meter: 19 | Flash files count is :11 Action : Firmware update. Selected Model: Qmobile: QMobile I6 metal Exe version: Avengers Box MTK 0.5.0 Scenario: [5]Full format + Full Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB Port (COM23) Boot mode: Brom Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... Scatter file loaded, not need emmi. Second stage DA fail, aborting BBCHIP MT6580 flash id: 484A01906531473836 [S_FT_ENABLE_DRAM_FAIL]Exe not support this emmi settings Please load scatter and preloader from phone fimware Boot Fail.!!!. All done. |
07-16-2018, 16:00 | #4 (permalink) |
Insane Poster Join Date: Jan 2005 Age: 39
Member: 107148 Status: Offline Thanks Meter: 38 | Success Report You Are Using Wrong Configurations. Use CM2SCR and Select SC6331 Rev E See This http://forum.gsmhosting.com/vbb/f296.../#post13225999 |
07-16-2018, 16:12 | #5 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,636 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
