06-06-2016, 11:04 | #1 (permalink) | ||||
No Life Poster Join Date: Jul 2006 Location: punjab Age: 43
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | pls pls team fix this problem Quote:
flash mode always failed com mode some times working if their is not com mode option then what i do pls fix this you know after format mtk seq damage and must to reapire it but i cant | ||||
06-07-2016, 06:01 | #2 (permalink) | |
No Life Poster Join Date: Oct 2007
Member: 608516 Status: Offline Sonork: 100.1607007 Thanks Meter: 123 | Quote:
06-10-2016, 08:43 | #5 (permalink) |
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | same problem Operation : Check / Read Info [ v1.49 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 21 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 8D54F32A8829B33B6BDB8F8004402D44 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 Done! Elapsed: 00:00:05 Reconnect Power/Cable! Operation : Repair Security [ v1.49 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 21 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 8D54F32A8829B33B6BDB8F8004402D44 BROM Protocol Version : 05 Setting Service Mode ... Init Service mode failed, something went wrong Reconnect Power/Cable! phone has no com port now what i do next |
06-17-2016, 14:48 | #7 (permalink) |
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | still not works for me Chinese Miracle II [MTK module] v 1.50 Operation : Check / Read Info [ v1.50 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 30 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : B76C1068BBD8974B33C1569E0A915366 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3700 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DC , [MX] MX25U6435E [0] : FLASH_DIE : 00C2 0025 0037 0000 [0] : FLASH_LEN : 0x00800000 INT_RAM : 0x0000D400 EXT_RAM : 0x00800000 File_Info : LEATEK50_6464_11B_PCB01_gprs_MT6250_S00.L_2233G_V1 _4_1.bin FileVersion : L_2233G_V1.4.1 Done! Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Format FileSystem [ v1.50 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 30 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : B76C1068BBD8974B33C1569E0A915366 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3700 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DC , [MX] MX25U6435E [0] : FLASH_DIE : 00C2 0025 0037 0000 [0] : FLASH_LEN : 0x00800000 INT_RAM : 0x0000D400 EXT_RAM : 0x00800000 Backup exists , skip Executing FFS FORMAT now... FAT_RANGE : 0x00700000-0x007FFFFF , LEN : 0x00100000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:21 Reconnect Power/Cable! Operation : Repair Security [ v1.50 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 30 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : B76C1068BBD8974B33C1569E0A915366 BROM Protocol Version : 05 Setting Service Mode ... Init Service mode failed, something went wrong Reconnect Power/Cable! its gfive w1 4 sim phone |
06-17-2016, 14:56 | #8 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
Post results | |
06-17-2016, 15:41 | #9 (permalink) |
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | direct mode works thanks cm2 Chinese Miracle II [MTK module] v 1.50 Operation : Repair Security [ v1.50 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 30 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : B76C1068BBD8974B33C1569E0A915366 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3700 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DC , [MX] MX25U6435E [0] : FLASH_DIE : 00C2 0025 0037 0000 [0] : FLASH_LEN : 0x00800000 INT_RAM : 0x0000D400 EXT_RAM : 0x00800000 Read Security data ... Verify Security data ... Set IMEI [0] : 868261 Set IMEI [1] : 868261 Set IMEI [2] : 86826 Set IMEI [3] : 868261 Repair Repair done! Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
The Following User Says Thank You to diesel6 For This Useful Post: |
