Qmobile R480 Fp Phone Imei Repair Done With CM2 Direct Imei Method Code:
Operation : Repair Security [ v1.50 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 117 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 30756729D75E64B26C887E545E5DEB18
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32
[0] : FLASH_DIE : 00C8 0060 0016 0000
[0] : FLASH_LEN : 0x00400000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
Read Security data ...
Verify Security data ...
Set IMEI [0] : 358242060399801
Set IMEI [1] : 358242060399819
Repair
Repair done!
[Info] : Make "Format/Reset Settings" procedure before start phone!
Done!
Elapsed: 00:00:07
Reconnect Power/Cable! |
