01-24-2018, 11:46 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: usa
Member: 2372074 Status: Offline Sonork: 100.1663814 Thanks Meter: 167 | qmobile s6 after flashing dead Files found : 9 , Set to Flash : 8 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile Device Model : QMobileS6 Device CPU : MT6580 Device IntName : QMobileS6 Device Version : 6.0 Device Compile : 8/24/2016 9:57:06 AM Device Project : D3679_DD36791_QMOBILE-S6_L109 Device ExtInfo : QMobile S6 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 103 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100514531334D420D9C4BB87D3475 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:36 Reconnect Power/Cable! |
03-22-2018, 17:06 | #4 (permalink) |
Member: 2372074 Status: Offline Sonork: 100.1663814 Thanks Meter: 167 | 1 perloader flash first l118 file cm2 2 flash sp flash tool full firmware only click thanks |
The Following 3 Users Say Thank You to ahmerrafiq30 For This Useful Post: |
06-13-2018, 05:18 | #6 (permalink) |
No Life Poster Join Date: Apr 2015 Location: LOOLCANO Taba Day.
Member: 2385819 Status: Offline Sonork: No More Used Thanks Meter: 827 | |
