12-13-2016, 13:03 | #1 (permalink) |
Freak Poster Join Date: Nov 2015 Location: Pakistan lahore
Member: 2482838 Status: Offline Sonork: 100.1676271 Thanks Meter: 442 | Qmobile X32 v3 flash file World First Qmobile X32 V3 Spd Frp Rmove Done Factory Firmware Raed Done With Great TOol Cm2 Here is info Code: Card found: S/N : 454F9D64 , v0134 Chinese Miracle II [SPD module] v 1.24 Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 41 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000012ABF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:25 Reconnect Power/Cable! Code: Operation : Read FullFlash [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 41 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Prepare Ok! - > Wait phone connected ... Phone found! [ 41 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! - > Wait phone connected ... Phone found! [ 41 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : X32 Model Brand : QMobile Model Device: X32 AndrVersion : 6.0 BaseBand CPU: X32 Project Ver : MRA58K release-keys Model Ext : QMobile X32 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731C_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W16.28.5_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x800.bin [Read Ok] : fblogo_480x800.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : sysinfo.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 2579 MiB Saved to : C:\Users\khizar\Desktop\X32_X32_6.0_MRA58K_release-keys_QMobile_X32\ Done! Elapsed: 00:10:06 Reconnect Power/Cable! Br khizar.ali |
The Following 6 Users Say Thank You to khizar.ali For This Useful Post: |
01-10-2017, 10:24 | #2 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Punjab
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | which option did you chose in cpu setting? i am trying but nit sucess |
The Following User Says Thank You to darmobiles For This Useful Post: |
02-15-2017, 08:37 | #5 (permalink) |
Freak Poster Join Date: Mar 2014 Location: swabi kpk
Member: 2139605 Status: Offline Thanks Meter: 31 | Q X32 v3 FRP rest done on CM2 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000012ABF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
12-20-2017, 12:03 | #10 (permalink) |
No Life Poster Join Date: Jan 2015 Location: STATE OF JAMMU & KASHMIR
Member: 2327602 Status: Offline Sonork: 100.1620953 Thanks Meter: 276 | Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile Device Model : X32 Device CPU : X32 Device IntName : X32 Device Version : 6.0 Device Compile : 10/19/2016 8:38:17 AM Device Project : MRA58K release-keys Device ExtInfo : QMobile X32 https://mega.nz/#!og82EBKK!MqQhRemj0...O5ON2X-7G4maf0 |
The Following User Says Thank You to shazzmob For This Useful Post: |
12-21-2017, 07:21 | #11 (permalink) | |
Junior Member Join Date: Jun 2016 Location: Bhawalnagar Pakistan
Member: 2589837 Status: Offline Thanks Meter: 3 | Quote:
02-06-2018, 14:44 | #14 (permalink) | |
Member: 2327602 Status: Offline Sonork: 100.1620953 Thanks Meter: 276 | Quote:
ALL MOBILE USB DRIVER GIFT FOR CM2 USER,S https://mega.nz/#F!Z8tmlRxZ!ZbiHkVBtOClJytd57P2u3g | |
02-07-2018, 19:44 | #15 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,989 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
