11-03-2015, 11:33 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Mountains
Member: 276322 Status: Offline Thanks Meter: 293 | Micromax A107 1 считать граф ключ. 2 считать контакты 3 прошивку под завод. стандарт Фулл слил, на форуме su есть ссылка и логи Code: Read Ok , collect info Brand : Micromax ProdName : A107 ProdModel : Micromax A107 Device : A107 AndroidVer: 5.0 MTKxCPU : MT6582 MTKxPRJ : MMX_A107_SW_V0.0.8_HW_V1.0_140415_RU |
11-03-2015, 11:48 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. MMX A107 have encrypted from factory FileSystem. Possible to decrypt, but not sure about user will wait from one week to few years, when sw decrypt keys. It about userData. Fw reading - there is workaround for such phones : 1.Repair ExtData 2.Power On phone, insert USB cable , press "FW read". 3. In some case need press "Read FW" one time more, due timeout of connection try. This allow read fw from ANY encrypted phone , BUT IT KILL ALL USERDATA! |
11-03-2015, 12:47 | #3 (permalink) | |
Member: 276322 Status: Offline Thanks Meter: 293 | Quote:
in the ON state is not connected ... are my options? Code: Operation : Read Flash [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:28 Reconnect Power/Cable! | |
11-03-2015, 13:00 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | After phone ON it will go to recovery for make finalize operations after EXTRepair. In that moment need connect cable and press Read FW button , when phone OFF itself, after finish operations - it will connect in boot mode , sw catch it and read FW. As told before - in some case need press it 1-2 times, because phone can take more, than 20-30 seconds for finish operation. |
11-03-2015, 13:42 | #5 (permalink) | |
Code: Operation : Read Flash [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4838473165050713C0210842C3 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : e1G8 [eMMC] : FLASH_CID : 90014A4838473165050713C0210842C3 [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Micromax ProdName : A107 ProdModel : Micromax A107 Device : A107 AndroidVer: 5.0 MTKxCPU : MT6582 MTKxPRJ : MMX_A107_SW_V0.0.8_HW_V1.0_140415_RU [Read Ok] : preloader_zaw619.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / zaw619 / EMMC FW Size : 1854 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6582__Micromax__Micromax A107__A107__5.0__MMX_A107_SW_V0.0.8_HW_V1.0_140415_RU\ All done! Done! Elapsed: 00:07:15 Reconnect Power/Cable! | |
The Following User Says Thank You to gulka For This Useful Post: |
