Old 04-22-2015, 06:03   #1 (permalink)
Member: 608370
Thanks Meter: 89
qmoble x25 still hangs at logo
qmobile x25 hangs at logo. i took the other working phone and read the file with infinity box and wrote in the affected phone but not solved. any suggestion please by support and the great master. i have also tried on other tools and sptools of different version but not done
Operation : Flash [ v1.17 ]
======= Flash
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 90014A4834473164040502A1DD205193
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : d1G4
[eMMC] : FLASH_CID : 90014A4834473164040502A1DD205193
[eMMC] : FLASH_LEN : 0x00000000E9000000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4011 , Storage : EMMC
Setting : AFF verify : Enabled
SecCfg Passed , 1799
BL : Check HW compatibility
BL : Check eMMC compatibility
BMT remark not need. Will skip
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:11
BL : Clear old BL Data
BL : Clear old BL Data Ok
Sending Preloader ...
Use : preloader_s4011.bin
Preloader Sent , Init passed
PartCount : 0012
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:13
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:55
Update RomInfo done
Done!
Elapsed: 00:03:37
Reconnect Power/Cable!
Old 04-22-2015, 10:34   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Hello, Erase phone. CM2 - Extra - Flash Erase.
Reflash after.
Old 05-09-2015, 14:42   #3 (permalink)
Member: 2290305
Sonork: 1672955
Thanks Meter: 33
https://mega.co.nz/#!rg9zUKKK!PoF2U_...Xkpw8RFjAamoSI
Page generated in 0.23200 seconds with 8 queries
