qmoblie x33 frp help need i format but same how by pass frp qmobile x33 Phone found! [ 15 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Init Ok , reset settings ... Format Ok! Done Elapsed: 00:00:17 Reconnect Power/Cable! :o |
Untick Reset via SVC Then Do again |
which boot i select please help |
Hello, which cpu is in ur mobile read info with Servicemode then see which cpu having in mble then select |
Hello, Which cpu is inside phone? You can read info in SVC mode for info. Select CPU under setting according to phone cpu, try with/without ALTLDR mode. Br. Infinity Box Team. |
1. use search button. (there is recent post of same model ) 2. put phone in fastboot and reset frp using AST v1.01 Module. 3. select correct boot from setting and do required operation (Qmobile x33 have sc77xx cpu) select sc773x emmc 4.x or 5.x) 4. if you failed to select correct boot in setting , download below file and select pac in flash tab and do desire operation. http://130.211.210.249/tmp/x33.7z size: 13.1 MB |
Ok I try then post result . |
Phone found! [ 15 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! |
problem solved thanks for help write pac file |
