03-16-2017, 19:09 | #1 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Qualcomm MSM 8926 (SnapDragon 400) Need Help ZTE Blade Apex2 - Specifications I need to factory reset but phone will not be recognized in EDL Mode With Vol Down plus UP Pressed it will enter in DFU Mode aka ZTE Handset Diagnostic. Forced to install Emergency Drivers , drivers installed as Emergency but software will not detect it. I Use EDL Boot Cable too Same thing. Phone condition : Boot OK , when starting up xxxxx.com.process.stoped. Factory Reset and Clear Cache from recovery will not Help Any Idea or key combination to EDL Mode of This model. Thanks Last edited by Formingus; 03-16-2017 at 19:09. Reason: Add Word |
03-18-2017, 00:46 | #6 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,783 | Quote:
It's usually accessible after taking off the back cover... b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following User Says Thank You to Brka For This Useful Post: |
03-18-2017, 19:17 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I'm vote for 2x3 point group under metal cover, up from sim reader. 100-500 Ohm resistor and between horizontal line, battery reset required between every try. Then insert cable in device, when points shorted. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
03-18-2017, 23:59 | #9 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,783 | I agree with JayDi on that, it's usually close to CPU/eMMC, but as i saw on huawei y530, it may be near usb socket. so ... start connecting two by two, and after connect insert usb cable, it should appear as emergency downloader port. i attached picture with possible points location ... (and possible "best luck" point) b.r. Alex
The Following 2 Users Say Thank You to Brka For This Useful Post: |
03-21-2017, 20:19 | #10 (permalink) |
Member: 322417 Status: Offline Thanks Meter: 940 | Guys Thanks For Replay and sorry for mine Delay I had problems with PC , Installing all stuffs from begin Will give a shoot and post replay Thanks Again |
