12-27-2016, 15:06 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: FOCSANI Age: 39
Member: 718470 Status: Offline Thanks Meter: 79 | Qualcomm MSM8937 not conecting ?? Operation : Reset Settings [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! I conect TP to force EDL in device manager Qualcomm HS-USB QDLoader 9008 ??? ? |
12-27-2016, 15:12 | #2 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
In device manager u need to install Emergency drivers how to install check this theard http://forum.gsmhosting.com/vbb/f296...video-2160627/ | |
The Following User Says Thank You to princesaddam For This Useful Post: |
12-27-2016, 15:25 | #3 (permalink) |
Member: 718470 Status: Offline Thanks Meter: 79 | error reset phone pin or xiaomi account ? Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 430 [MSM8937] ID_BLOCK_S : 00607D69 ID_BLOCK_I : 0004F0E1 ID_BLOCK_L : E5A2211DAFA66A4D4418A89F73E31B3C ID_BLOCK_L : 28D4AE05C8E3E33B24875C4730A67237 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : Q313MB Boot Ok! Error : FS verification fail! Encrypted or damaged! Reconnect Power/Cable! Operation : Reset Settings [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 430 [MSM8937] ID_BLOCK_S : 00607D69 ID_BLOCK_I : 0004F0E1 ID_BLOCK_L : E5A2211DAFA66A4D4418A89F73E31B3C ID_BLOCK_L : 28D4AE05C8E3E33B24875C4730A67237 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] |
The Following User Says Thank You to gsmiulian For This Useful Post: |
12-27-2016, 16:01 | #7 (permalink) |
Member: 718470 Status: Offline Thanks Meter: 79 | So infinty not support s3 redmi password or xiaomi accont phone starts does not have any problem, it is encrypted by Xiaomi. infinty not support ok? |
12-27-2016, 18:06 | #12 (permalink) |
Member: 718470 Status: Offline Thanks Meter: 79 | you should have a little sense of respect. and if you are able to answer or to help someone. help .If you have not even the decency not to offend anyone I did not hurt anyone and so I asked for help |
