07-11-2020, 00:31 | #1 (permalink) |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 735 | Quastion about redmi 6a imei repair With eng rom its possible with eng rom And Erase nvrom and nvdata And maui meta by write only sim 2 (if write sim 1 imei phone will stock on recovery and show nv damge) But just wanna Know there is a way to write dual sim with cm2mt2? |
07-11-2020, 09:07 | #2 (permalink) |
Member: 1876736 Status: Offline Thanks Meter: 735 | not working on eng rom Code: PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META enter failed by timeout! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Repair Security [ v2.12 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META enter failed by timeout! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Repair Security [ v2.12 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM77) MODE : BOOTROM PORT : 77 Error : Failed to open port! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Repair Security [ v2.12 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM77) MODE : BOOTROM PORT : 77 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : 947ABE42F0557A39AC68F4FDEA809EAFDBEA4702BE78FF54A308D668AE60CAD7 BROM : Configuring target for META BROM : Failed to setup environment! ErrorCode : 0x0000 : 0x1D0D Unknow Error! >>> Check previous message for more info! Reconnect Power/Cable! |
07-12-2020, 09:58 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | It not should work at all, does bootloader unlocked? Or maui can boot it? As can see, from brom, device rejects anything and asks for SLA AUTH. If it not enter from preloader mode, then meta will not work. IN 6A both IMEI's and MAC's, SN are RSA signed. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
07-12-2020, 12:13 | #4 (permalink) | |
Member: 1876736 Status: Offline Thanks Meter: 735 | Quote:
And eng Firmware writed Maui meta can boot this on meta But cm2mt2 not have that Option to device already on meta I Erase nv data and nvrom from fastboot I write only imei 2 by maui meta becuse when i write dual imei phone stock on recovery and give nv data damged But when write only one imei phone is ok | |
07-12-2020, 12:20 | #5 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Will fix that in near update-two. About first imei then - seems as it common xiaomi bug or feature, when first null and second work. Writing first one will enforce security verification and sure, it will fail, because signature removed or wrong. Signature paired to device CPU. | |
The Following 5 Users Say Thank You to JayDi For This Useful Post: |
07-12-2020, 18:43 | #6 (permalink) | |
No Life Poster Join Date: Mar 2016 Location: IN THE KERNEL
Member: 2545468 Status: Offline Thanks Meter: 234 | Lord! Quote:
