Old 02-17-2008, 01:44   #1 (permalink)
Member: 678782
Unhappy I need N88 Flash file
hello
i have a NEC.COM N88 1*18 pin
with rx:4 tx:9
it s dead after format & i havent any backup of eeprom or flash file
i searched in support site but dont find it
its ver sw1 is
CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_21_26B_CQ_L6 RU_RCH_112_070529_LD-TR0_OV0_SS75_CTF_BT.BIN
log on format complete:
Do you want to continue ?
COM3 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: reset
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
chip: 0031:767E:9676
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:2CEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 damaged, recalculation required
identification#1 detection finished
device-id: 9401B8CC
identification#1 protocol ver: 04
ver. sw1: CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_21_26B_CQ_L6 RU_RCH_112_070529_LD-TR0_OV0_SS75_CTF_BT.BIN
ver. sw2: LION6_21_26B_CQ_L6RU_RCH_112_070529_LD-TR0_OV0_SS75_CTF_BT, 6CC8A936
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
reading [eeprom[CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_21_26B_CQ_L6 RU_RCH_112_070529_LD-TR0_OV0_SS75_CTF_BT.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_21_26B_CQ_L6 RU_RCH_112_070529_LD-TR0_OV0_SS75_CTF_BT.BIN]_20080217-025921.B0E.bin
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
Finished, time used: 1624 sec
Remove/Install battery now !
i holded power On key for 40-60 sec but not power on
i tested repair security area but not power on
pls guide me
thanks a lot
Old 02-17-2008, 01:50   #2 (permalink)
Member: 678782
this is log of repair security dameged
Action: repair security area
Boot...
19200
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
Identification...
device-id: 9401B8CC
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.9401B8CC.[CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_21_26B_CQ_L6 RU_RCH_112_070529_LD-TR0_OV0_SS75_CTF_BT.BIN_C9563793].rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.9401B8CC._CKT2 6_06B_PCB01_GPRS_MT6226_S01.LION6_21_26B_CQ_L6RU_R CH_112_070529_LD-TR0_OV0_SS75_CTF_BT.BIN_C9563793_.rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9401B8CC.[CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_21_26B_CQ_L6 RU_RCH_112_070529_LD-TR0_OV0_SS75_CTF_BT.BIN_C9563793].rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9401B8CC._CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_ 21_26B_CQ_L6RU_RCH_112_070529_LD-TR0_OV0_SS75_CTF_BT.BIN_C9563793_.rpl
warning: unknown identification#1 structure: CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_21_26B_CQ_L6 RU_RCH_112_070529_LD-TR0_OV0_SS75_CTF_BT.BIN_C9563793
error: Unknown firmware, user action required:
1. download latest software from support area and try again !
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read detailed information" operation
- send "backup_system_log_..." file to support
- make "Read full flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
Finished, time used: 171 sec
Old 02-17-2008, 08:35   #3 (permalink)
zinoubinabil's Avatar
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,569
hello
plz go to support erea & make search with this firmware CKT26_06B_PCB01_GPRS_MT6226_S01
for more help check this link
http:///vbb/showthread.php?t=499453
br
Old 02-17-2008, 08:45   #4 (permalink)
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,569
dear
plz use search with this CKT26_06B_PCB01_GPRS_MT6226_S01
you can flash your phone with this firmwares one by one till your phone live again
br
Old 02-17-2008, 19:18   #5 (permalink)
Member: 678782
thanks alot but i tested many this files
it must flash with this flash file :
do you give me this file? very urgency
thanks
Old 02-17-2008, 21:37   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
unfortunatly, we dont have exactly same version firmware.
you must look for same working phone to read out backup or wait some forum member to share it with you
need this flash file. naeem janjua Infinity-Box 2 03-30-2010 15:13
i need kp135 flash file [USER REQUEST] sameenshah123 PolarBox 3 5 03-29-2010 16:08
i need 1650 flash file without games med26 Nokia Digital Core Technology 4 ( DCT-4 ) 0 03-29-2010 11:11
need 6021 flash file & pm file help me mohamedsafi123 Nokia Hardware & Hardware Repair 1 09-09-2006 08:16
Page generated in 0.20517 seconds with 9 queries
