10-03-2011, 21:47 | #1 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1566071 Status: Offline Thanks Meter: 0 | get mad on pin finder what i have? infinity box 2pics (all are working fine, i use them daily) , pin finder 2pics (both are brand new ), IP-12C+L14A 3pics (bought from IPMART tesco mojo chat phone 2pics what i connect ? 1, i bind infinity box with pin finder by dongle manager software , done 2. i connect infinity box to pc by usb cable , connect pin finder to infinity box by rj45 cable , connect IP-12C+L14A to pin finder . connect 12C port to phone . problem ? look like software canot see phone , question? A, connection is correct ? B.when we unlock phone . for pin finder ,power green light must on ? red mode light must be on ? C. use battery or rj45 power cable from pin finder pack ? D. switch on infinity box is upper ? correct i thought problem is from pin finder or infinity box , however, i did try on another set . still no luck , pls advice , thanks Last edited by badunlocker; 10-03-2011 at 21:56. |
10-09-2011, 14:09 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | I am sorry for delay with reply. Let me move this thread to "PinFinder" forum and my partner InfinityHelp will try to help you with your problem. |
10-09-2011, 20:41 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! pinfinder paired, ok. you run pinfinder software, press detect adapter. 1. does software successfully detect adapter? 2. connect L12C to phone port, select L12C in software, connect power wires (red & black) to phone's battery terminals. Press "power On", check if phone can be powered On. does it? 3. run pinout search. what result you get? please post log 4. which CPU type is used in your phone? |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
