question for infinty team hi can u define meaning for these terms in latest update LOD DNVM FTM HARD LOCK Quote:
Hi, There is a some kind of special feature in latest phones, so called "HardLock", and this feature is under test in latest update. DNVM and FTM - it's special terms that may be useful for programmers, coders and developers. In most cases ordinary software users may leave these terms like they leave all other terms like BROM, RSA, ROM, RAM, SRAM, DRAM, CPU, MCU, FPU, GPU etc. For you both mentioned terms means that when you press software button for most of operations software makes more deep test of your phone, clean data much better, format file system with special unique methods and as a result unique methods used by Intiniy Team gives you big advantage during phone repair process. |
Let's start from easy things. Can you explain to other users with your own words what is CPU means ? |
CPU Central Processing Unit OR BRAIN OF COMPUTER PHONE ETC |
How about MCU ? And also what is the difference in RAM/SRAM/DRAM ? |
MCU MicroController Unit RAM random access memory SRAM Static random-access memory DRAM Dynamic random-access memory |
Your first explanation was very good and very easy for many people. Ok, what is the difference CPU and MCU ? |
im not programmer just user want know terms for self knowledge thanK you |
And your example with wikipedia text about RAM/SRAM/DRAM says that these terms just a noice for most people. In most cases users should have just a good practice but thousands of "scientific terms" gives zero help if users do not understand RAM type difference, address space, processor commands etc. Af first users should learn basic things about processors, memory, programming etc. but not "unknown terrible scientific terms" meaning. |
i agree with u most of users have zero knowledge and this made to teach users as team as can we are not looking for very detailed info just brief so now what functuon of hard lock LOD |
people with "brief" start to say everywhere that they are very experienced, they can write scientific words but they do not understand what is the real power of that words. "brief" is a wrong way. if somebody really want to get success he must spend thousands hours in reading. it is very hard way. but you are right. next time I will remove all unknown words from software release text. Team must make easy solutions that is good for all people around and do not use very specific words. |
as me understand that hard lock may be some kind Hard disk lock, that nothing could be change untill Hard lock open so. . . for that "Hard lock" option. . . :confused::confused::confused: and after unlock the hard you can perform SP unlock option. |
anyway in brief answers are: Quote:
if you want to know more about hard or permanent lock types you can start with reading about OTP OTP has thousands of meanings so you should read about Code: One-time programmable, a type of programmable read-only memory in electronics |
fs means file system file system means set of rules how is files stored inside memory nvm means NVM but we talk about this NVM Non-volatile memory may have many different options. letter d before terms very often has meaning dynamic. ftm may be factory test mode but also it may be field test mode (very useful feature) |
@profkefah two more words about very popular term dynamic. dynamic is something changeable or configurable, it's an opposit sde of term static. static in most cases means something that should be configured only once, f.e. at factory or during initial programming |
