12-21-2009, 22:19 | #1 (permalink) |
Junior Member Join Date: Jan 2004 Age: 50
Member: 50348 Status: Offline Thanks Meter: 0 | R300 Dead after sp Unlock module v1.37 Device: Sony-Ericsson-R300 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb software version: 1209-4521 software version: R2BB012 Check hardware done Read data ... reading Sony-Ericsson-R300_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-R300_eeprom_calibration-1_20091217-194243.80E.bin Read data done Check data ... Check data done Write ... ........................... flash: 89890400040089:89890400000000 Write: simlock error: no any expected answer error: flash write error: 066DC000:00002000 error: no any expected answer error: flash write error: 066DC000:00002000 error: unexpected termination/freez: 06000000 error: unknown structure, read flash and send to support ! Write fail error: operation failed Finished, time used: 255 sec Remove/Install battery now ! |
12-21-2009, 22:28 | #2 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
hi sir.. operation is not finished successfully.. did u try to recover phone by eeprom backup...? | |
12-21-2009, 23:38 | #3 (permalink) | |
You need to charge battery completely with external power supply. Flash phone fir firmware + flex. Make sp-unlock operation again. | |
12-22-2009, 08:36 | #4 (permalink) |
Member: 50348 Status: Offline Thanks Meter: 0 | Thanks for reply I had got the phone for phone lock code ,I tried format ffs but the phone code did not go , then i tried sp unlock and phone got dead. I wrote back eeprom also still dead. now the phone is not responding for read flash write flash only red light stays on as i connect cable. |
R300 dead after unlock revive by infinity | ayhen42 | Infinity-Box | 4 | 05-18-2009 21:44 |
SE R300 dead after flashing | Nestor7 | SETool2 | 3 | 11-27-2008 08:18 |
c139 BLANK SCREEN AFTER sp unlock | PASSIONATE_BOYS | Infinity-Box | 6 | 09-19-2008 14:46 |
S700 very strage after sp-unlocking | returburk | SonyEricsson (USB-Smart) | 3 | 04-15-2006 15:03 |
c10 disable after sp unlock | Platijet | x1x to x45/x50 | 7 | 06-01-2004 00:30 |
