05-31-2018, 12:31 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Location: Ukraine Age: 42
Member: 61559 Status: Offline Thanks Meter: 12 | Read from alive meizu m6 fullflash not write in other meizu m6 Operation : Read Firmware [ v2.00 r3 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM8) MODE : PRELOADER PORT PORT : 8 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000007 BROM : SecMode : SBC+SLA+SDA BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 450100444634303136012D1CEAA4744F EMMC: VEN : SANDISK | OEM : 01 | DEV : DF4016 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3AB400000 [ 14,68 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 36F575DB2986941238BD0AA5E0653DB8 DA : USB : HIGH-SPEED Boot done! MT6755 Read : preloader.bin Read : recovery.img Read : custom.img Read : proinfo.img Read : devinfo.img Read : md1rom.img Read : md1dsp.img Read : md1arm7.img Read : md3rom.img Read : nvram.bin Read : lk.bin Read : boot.img Read : logo.bin Read : tz.img Read : secro.img Read : system.img Read : cache.img Read : userdata.img FW Size : 3,19 GB Scatter : MT6755_Android_scatter.txt Saved to : D:\MT6755\ Done! Elapsed: 00:03:05 Write flash: Preloader [HW DEV] Info : EMI : DEV : MT6755 EMI : SRC : preloader_wt6750s_66_s11_n.bin EMI : CNT : 0004 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2,00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 450100444634303136 : VEN : SANDISK | DEV : DF4016 : RAM : [ 2,00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3,00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3,00 GB ] Operation : Write Flash [ v2.00 r3 ] Repartition : Disabled Flash Verify : Disabled Pre-Erase : Enabled Verify HW/SW : Disabled XData Backup : Disabled Files :18 [FL] : Set : preloader_wt6750s_66_s11_n.bin [FL] : Set : preloader_wt6750s_66_s11_n.bin [FL] : Set : recovery.img [FL] : Set : custom.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : md1arm7.img [FL] : Set : md3rom.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : secro.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xCC33A740 [ 3,19 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM8) MODE : PRELOADER PORT PORT : 8 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000007 BROM : SecMode : SBC+SLA+SDA BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256,00 KB ] DRAM: 0xC0000000 [ 3,00 GB ] EMMC: 90014A484247346132A554F526E024DF EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x747C00000 [ 29,12 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : AB762823A08BFCE35D8E2975C8B486F7 DA : USB : HIGH-SPEED Boot done! [FL] : Flashing now ... Write : PRELOADER ERR : 0xC0020004 ERR : SEC_DL_FORBIDDEN ERR : 0x00000000|0x00029D00 Error : Flashing failed! Seems as some of MANDATORY section of FW is damaged! If device alive and work - send report! Reconnect Power/Cable! |
05-31-2018, 12:42 | #2 (permalink) | |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 735 | Quote:
Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list! | |
The Following User Says Thank You to sky73 For This Useful Post: |
05-31-2018, 13:59 | #3 (permalink) |
Member: 61559 Status: Offline Thanks Meter: 12 | untick but next block recovery too error. may be read from 16 gb: SRAM: 0x00040000 [ 256,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 450100444634303136012D1CEAA4744F EMMC: VEN : SANDISK | OEM : 01 | DEV : DF4016 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3AB400000 [ 14,68 GB ] and write in to 32 gb: SRAM: 0x00040000 [ 256,00 KB ] DRAM: 0xC0000000 [ 3,00 GB ] EMMC: 90014A484247346132A554F526E024DF EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x747C00000 [ 29,12 GB ] |
05-31-2018, 19:17 | #5 (permalink) |
Member: 61559 Status: Offline Thanks Meter: 12 | UNTICK "PMT Update" and "PRELOADER" partition from flashing list: Card found : 44715C25 , v0136 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r3 Preloader [HW DEV] Info : EMI : DEV : MT6755 EMI : SRC : preloader_wt6750s_66_s11_n.bin EMI : CNT : 0004 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2,00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 450100444634303136 : VEN : SANDISK | DEV : DF4016 : RAM : [ 2,00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3,00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3,00 GB ] Operation : Write Flash [ v2.00 r3 ] Repartition : Disabled Flash Verify : Disabled Pre-Erase : Enabled Verify HW/SW : Enabled XData Backup : Disabled Files :16 [FL] : Set : recovery.img [FL] : Set : custom.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : md1arm7.img [FL] : Set : md3rom.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : secro.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xCC2E6D40 [ 3,19 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000007 BROM : SecMode : SBC+SLA+SDA BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256,00 KB ] DRAM: 0xC0000000 [ 3,00 GB ] EMMC: 90014A484247346132A554F526E024DF EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x747C00000 [ 29,12 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : AB762823A08BFCE35D8E2975C8B486F7 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! [FL] : Flashing now ... Write : RECOVERY Write : CUSTOM ERR : 0xC0020005 ERR : SEC_IMG_TOO_LARGE ERR : 0x00000000|0x20000000 Error : Flashing failed! Seems as some of MANDATORY section of FW is damaged! If device alive and work - send report! Reconnect Power/Cable! |
05-31-2018, 19:25 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hm... Have no idea why sw verify custom content, since it EXT4. Skip that partition also. Mandatory main boot chain, system. So, untick custom, persist and other, if they not want to be flashed. |
05-31-2018, 19:45 | #7 (permalink) |
Member: 61559 Status: Offline Thanks Meter: 12 | [FL] : Flashing now ... Write : RECOVERY Write : MD1IMG Write : MD1DSP Write : MD1ARM7 Write : MD3IMG Write : LK Write : LK2 Write : BOOT Write : LOGO Write : TEE1 Write : TEE2 Write : SECRO Write : SYSTEM Write : CACHE Write : USERDATA [FL] : Flashing finished! Done! Elapsed: 00:02:28 Reconnect Power/Cable! |
06-21-2018, 05:15 | #9 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2681836 Status: Offline Sonork: WheiekLD Thanks Meter: 0 | I have the same problem, I got a Meizu M6 with skipper, I tried to do a "format all" with miracle but I could not stand it, I opened the NCK Box and I gave "Wipe Format" and the phone went off, every time I try to do something to him, it stays with me in "Boot mode: brom" and from there it does not happen, any solution? Sorry for the spelling mistakes, I do not know the English language and I am using a translator. |
06-21-2018, 05:25 | #10 (permalink) | |
No Life Poster Join Date: Mar 2009 Location: earth
Member: 992568 Status: Offline Sonork: kulit Thanks Meter: 231 | Quote:
asking why because you dont know exactly what you questing for consult the future teller and you will solved this http://forum.gsmhosting.com/vbb/f296...pdate-2412535/ | |
