09-20-2008, 11:55 | #1 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 306026 Status: Offline Thanks Meter: 111 | read error always read error i found it and many phone models like iphone china,and etc now i try to read Gbell but always error trying from lowest speed but always error Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:1D41:3F64 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung D 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung D 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 230400 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung D 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung D 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.CDF20B8A.[E558_ZZY1SMTRFP2L_E558_GPRS_MT6226_S01.01_2.BIN_5A 14CDE2].rpl ==================== New firmware detected: E558_ZZY1SMTRFP2L_E558_GPRS_MT6226_S01.01_2.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: CDF20B8A identification#1 protocol ver: 04 ver. sw1: E558_ZZY1SMTRFP2L_E558_GPRS_MT6226_S01.01_2.BIN ver. sw2: E558_ZZY1SMTRFP2L.01.2, 1D32EBA5 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: flash[E558_ZZY1SMTRFP2L_E558_GPRS_MT6226_S01.01_2.BIN]... warning: wrong cs at 0x0014A400, retry... read error recovered warning: wrong cs at 0x00291000, retry... warning: wrong cs at 0x00291000, retry... warning: wrong cs at 0x00291000, retry... warning: wrong cs at 0x00291000, retry... warning: wrong cs at 0x00291000, retry... warning: wrong cs at 0x00291000, retry... warning: wrong cs at 0x00291000, retry... warning: wrong cs at 0x00291000, retry... warning: wrong cs at 0x00291000, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? error: wrong answer: A1 Probably errors exist during flash read operation. Do you want to repeat read operation ? warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? error: wrong answer: 32 Probably errors exist during flash read operation. Do you want to repeat read operation ? warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? operation canceled by user file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_CDF20B8A_E558_ZZY1SMTRFP2L_E558_GPRS_MT6 226_S01.01_2.BIN_5A14CDE2_20080921-035348.B0X.bin Finished, time used: 304 sec Remove/Install battery now ! Last edited by mj_0990; 09-20-2008 at 12:02. |
09-20-2008, 13:08 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! spiderman and MTK tool do not use "control for errors" so even reading faulty flash will give out backup but this backup will be with errors, unuseable for future use |
09-20-2008, 14:04 | #4 (permalink) | |
Member: 306026 Status: Offline Thanks Meter: 111 | Quote:
but why i can use it to change language with infinity editor??? backup with mtk tool> load to infinity editor> load dict>save>start miracle and miracle happen but why i cant read the flash with infinity | |
09-20-2008, 14:42 | #5 (permalink) |
Member: 306026 Status: Offline Thanks Meter: 111 | error again this is never happen on earlier version 19200 autodetect Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:9AFF:3202 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung D 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung D 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung D 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung D 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... warning: wrong cs at 0x00000314, retry... read error recovered detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation warning: wrong cs at 0x002DBA04, retry... read error recovered warning: wrong cs at 0x002DD204, retry... warning: wrong cs at 0x002DD204, retry... read error recovered warning: wrong cs at 0x002DDE04, retry... read error recovered warning: wrong cs at 0x002DE204, retry... warning: wrong cs at 0x002DE204, retry... warning: wrong cs at 0x002DE204, retry... warning: wrong cs at 0x002DE204, retry... warning: wrong cs at 0x002DE204, retry... warning: wrong cs at 0x002DE204, retry... warning: wrong cs at 0x002DE204, retry... warning: wrong cs at 0x002DE204, retry... read error recovered warning: wrong cs at 0x002DB608, retry... read error recovered warning: wrong cs at 0x002DBA08, retry... read error recovered warning: wrong cs at 0x002DC208, retry... warning: wrong cs at 0x002DC208, retry... warning: wrong cs at 0x002DC208, retry... warning: wrong cs at 0x002DC208, retry... warning: wrong cs at 0x002DC208, retry... warning: wrong cs at 0x002DC208, retry... read error recovered warning: wrong cs at 0x002DC608, retry... read error recovered security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.F0167022.[SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.SZMI26_05C_W0 628_S619_SET.BIN_4FD89BA1].rpl identification#1 detection finished device-id: F0167022 identification#1 protocol ver: 04 ver. sw1: SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.SZMI26_05C_W0 628_S619_SET.BIN ver. sw2: SZMI26_05C_W0628_S619_SET, 5E6427B0 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: flash[SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.SZMI26_05C_W0 628_S619_SET.BIN]... warning: wrong cs at 0x00000800, retry... warning: wrong cs at 0x00000800, retry... warning: wrong cs at 0x00000800, retry... warning: wrong cs at 0x00000800, retry... read error recovered warning: wrong cs at 0x00001400, retry... read error recovered warning: wrong cs at 0x00001800, retry... warning: wrong cs at 0x00001800, retry... read error recovered warning: wrong cs at 0x00003000, retry... warning: wrong cs at 0x00003000, retry... warning: wrong cs at 0x00003000, retry... warning: wrong cs at 0x00003000, retry... warning: wrong cs at 0x00003000, retry... read error recovered warning: wrong cs at 0x00004800, retry... read error recovered warning: wrong cs at 0x00005000, retry... read error recovered warning: wrong cs at 0x00005400, retry... read error recovered warning: wrong cs at 0x00006400, retry... read error recovered warning: wrong cs at 0x00007800, retry... warning: wrong cs at 0x00007800, retry... warning: wrong cs at 0x00007800, retry... warning: wrong cs at 0x00007800, retry... warning: wrong cs at 0x00007800, retry... warning: wrong cs at 0x00007800, retry... warning: wrong cs at 0x00007800, retry... warning: wrong cs at 0x00007800, retry... warning: wrong cs at 0x00007800, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? operation canceled by user file saved: C:\Program Files\InfinityBox\ChineseMiracle\flash[SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.SZMI26_05C_W0 628_S619_SET.BIN]_20080921-063944.B0M.bin file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_F0167022_SZMI26_05C_SET_PCB01_GPRS_MT622 6_S01.SZMI26_05C_W0628_S619_SET.BIN_4FD89BA1_20080 921-063946.B0X.bin Finished, time used: 115 sec Remove/Install battery now ! please fix it why all cant read all phone which one error??? the phone or infinity???? i choose my infinity box how about you guys |
09-20-2008, 17:02 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Why you did not posted full log text but skip first messages from log ? Your problem is NOT with Infinity-Box but your problem is with bad cable ! Please, tell me honestly that you did not used high-quality Infinity-Box FTDI-based unibox but you have used bad quality chinese cable based on Prolific chip. Waiting for your information about your cable. |
09-22-2008, 13:16 | #8 (permalink) |
Member: 306026 Status: Offline Thanks Meter: 111 | gstar 808 error again COM1 [Serial2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:A24E:62CB high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb warning: wrong cs at 0x01000000, retry... read error recovered it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... warning: wrong cs at 0x00000398, retry... read error recovered detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation warning: wrong cs at 0x00334E60, retry... warning: wrong cs at 0x00334E60, retry... read error recovered error: unexpected data: 336C4D9ED2502947825605F6B6 warning: wrong cs at 0x00335260, retry... warning: wrong cs at 0x00335260, retry... warning: wrong cs at 0x00335260, retry... warning: wrong cs at 0x00335260, retry... read error recovered warning: wrong cs at 0x00336260, retry... read error recovered warning: wrong cs at 0x00336A60, retry... warning: wrong cs at 0x00336A60, retry... read error recovered warning: wrong cs at 0x00334A64, retry... warning: wrong cs at 0x00334A64, retry... warning: wrong cs at 0x00334A64, retry... warning: wrong cs at 0x00334A64, retry... warning: wrong cs at 0x00334A64, retry... warning: wrong cs at 0x00334A64, retry... warning: wrong cs at 0x00334A64, retry... warning: wrong cs at 0x00334A64, retry... warning: wrong cs at 0x00334A64, retry... error: too many retries during read operation security area#1 damaged, recalculation required identification#1 detection finished device-id: 0FFBD1DC identification#1 protocol ver: 04 ver. sw1: U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V04B39.BIN ver. sw2: UPU25U26V04B39, 5D192199 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... error: wrong answer: 00 . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 error: wrong answer: 00 : wrong answer after chip id request error: wrong answer: 00 : wrong answer after chip cfi request error: wrong answer: 00 : wrong answer after chip id request Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... error: wrong answer: 0B Check firmware content Fail Finished, time used: 69 sec Remove/Install battery now ! |
Card error 13 and card read error | smp_comms | MT-BOX | 0 | 02-04-2009 14:37 |
Card error 13 and card read error | smp_comms | BB5 Box by D.K. | 0 | 02-04-2009 12:51 |
C63X Read OK - FW Read Error ?!! | DZStorm | FuriousGold | 2 | 03-19-2007 15:13 |
Flash read error | nmp | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 01-05-2002 22:36 |
7110- 4.88. read error | Pat UK | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-17-2001 02:52 |
