Old 08-07-2020, 21:48   #1 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
oppo f7 imei null
i tay by test but failed
Operation : Repair Security [ v2.14 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM17)
MODE : BOOTROM
PORT : 17
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+ARB
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : Oppo : F7 | Manual : Enabled
BROM : SOCID : AD800A9ACEC19F78034563219E8F1519AD22B8F84D758E9BC7 4106278B64CC81
BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 [0200] F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 [0200] F3: 4000 0036 F7: 102D 0000 01: 102A 0001
BROM : SLA
BROM : SLA Passed!
BROM : SLA CHLNG not used
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_BR_HIGH.bin
AGENT : Found MT6771
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
EMI : CNT : 000E
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0xC0000000 [ 3.00 GB ]
EMMC: 90014A484347386134A54BAB8417A4A3
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HCG8a4
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0xE8F800000 [ 58.24 GB ]
CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 6D84D07718F458CFFB19BB40D8BDCA18
DA : USB : HIGH-SPEED
Boot done!
NVRAM check : Failed! NVRAM empty!
Done!
Elapsed: 00:00:30
Reconnect Power/Cable!
Old 08-08-2020, 01:33   #2 (permalink)
Member: 1535920
Thanks Meter: 31
Try to repair it through meta
Sent from my Redmi Note 5 using Tapatalk
Old 08-08-2020, 15:47   #3 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
note done meat mode basebande ok
Old 08-09-2020, 09:02   #4 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
cph1819 how put into metamode
Old 08-09-2020, 09:05   #5 (permalink)
Member: 1677653
Thanks Meter: 2,769
Hold both volume and connect,
Release all key once connected,
Install driver if require.
If not instal auto, try install manually.
If 1st operation failed, reboot phone & cm2mt2 then retry.
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 08-09-2020, 18:36   #6 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
not sucess there is 2 point to into meta mode
Old 08-09-2020, 21:50   #7 (permalink)
Registered User
Member: 2381725
Thanks Meter: 126
Initialize Modem or Modem Init this option fix nvram
Page generated in 0.15551 seconds with 8 queries
