01-05-2016, 11:19 | #1 (permalink) |
Freak Poster Join Date: May 2005 Location: Manila Age: 47
Member: 144565 Status: Offline Thanks Meter: 71 | read flash mt6571 emmc but backup cant write back to tablet.... tablet board id: hx m706p v2.0.0 tablet cpu: mt6571 flash id: emmc error when flashing backup to tablet, "This Firmware will kill phone!" logs here: BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A48594E49582079005418B66065 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , XINY [eMMC] : FLASH_CID : 90014A48594E49582079005418B66065 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6571 , Project : m706p_wvga_2g_port , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC NOT supported by BootLoader! [BL_ERROR] : STORAGE : Break Flashing! This Firmware will kill phone! any solution? |
01-05-2016, 11:30 | #5 (permalink) |
Member: 144565 Status: Offline Thanks Meter: 71 | ok after untick hw check... phone alive but in the state of hang in logo... when i do format reset the tablet from infinity box... tablet goes blinking again... do u have exact firmware for this... |
01-05-2016, 12:24 | #6 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Write backup firmware and do Repair ExtData after and switch on phone. Chances are low but may be it works. If still same then need good firmware. Br. Infinity Box Support Team. |
01-05-2016, 12:51 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Normally - there is no reason to read-write FW at same phone, if Repair ExtData or Format Fs not change anything - rewrite will give also nothing in most cases. |
