04-05-2016, 10:42 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | redmi note 3g 2013121 brick after flash first backup phonebook done Code: Operation : Read UserData [ v1.44 ] PhoneBook : Enabled PhoneBook : VCFv3 Format output Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040501898B5961DF Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501898B5961DF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 4B540D89054482367F1DD8C530A22A05 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processiung : PhoneBook extraction Step #1 Step #2 Read Ok, PhoneBook records extracted : 344 TXT Saved to : C:\InfinityBox\CM2MTK\PhData\arvind ji xiaomi MT6592_PhoneBook.txt Write : 344 CSV Saved to : C:\InfinityBox\CM2MTK\PhData\arvind ji xiaomi MT6592_PhoneBook.csv VCF Saved to : C:\InfinityBox\CM2MTK\PhData\arvind ji xiaomi MT6592_PhoneBook.vcf VCFv3 Saved to : C:\InfinityBox\CM2MTK\PhData\arvind ji xiaomi MT6592_PhoneBook_v3.vcf Done! Elapsed: 00:00:44 Reconnect Power/Cable! save images and video done Code: Operation : Read UserData [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040501898B5961DF Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501898B5961DF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 4B540D89054482367F1DD8C530A22A05 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Read UserData [ v1.44 ] Gallery : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040501898B5961DF Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501898B5961DF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 4B540D89054482367F1DD8C530A22A05 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processiung : User Photo/Video/Records extraction Reading : IMG_20160321_131021.jpg Reading : IMG_20160321_131105.jpg Reading : VID_20160329_184140.mp4 Reading : IMG_20160321_131112.jpg Reading : IMG_20160321_131251_HDR.jpg Reading : IMG_20160321_131307_HDR.jpg Reading : IMG_20160321_131315.jpg Reading : IMG_20160321_131533.jpg Reading : IMG_20160321_131538.jpg Reading : IMG_20160322_083846.jpg Reading : IMG_20160322_083848.jpg Reading : IMG_20160322_083850.jpg Reading : IMG_20160322_083854.jpg Reading : IMG_20160322_083857.jpg Reading : IMG_20160322_083926.jpg Reading : IMG_20160321_131705.jpg Reading : IMG_20160322_083927.jpg Reading : IMG_20160322_083930.jpg Reading : IMG_20160322_110908.jpg Reading : IMG_20160321_132519.jpg Reading : IMG_20160322_110915.jpg Reading : IMG_20160322_110917.jpg Reading : IMG_20160322_111108.jpg Reading : IMG_20160322_111118.jpg Reading : IMG_20160322_120556.jpg Reading : VID_20160323_131506.mp4 Reading : IMG_20160323_113108.jpg Reading : IMG_20160323_115947.jpg Reading : IMG_20160323_183718.jpg Reading : IMG_20160323_131608.jpg Reading : IMG_20160323_131613.jpg Reading : IMG_20160323_131618.jpg Reading : IMG_20160323_131623.jpg Reading : IMG_20160323_131628.jpg Reading : IMG_20160323_133502.jpg Reading : IMG_20160323_133507.jpg Reading : VID_20160323_152139.mp4 Reading : IMG_20160323_152211.jpg Reading : IMG_20160323_152216.jpg Reading : IMG_20160323_152220.jpg Reading : IMG_20160323_152232.jpg Reading : IMG_20160323_152244.jpg Reading : IMG_20160323_160557.jpg Reading : IMG_20160323_160628.jpg Reading : IMG_20160323_160636.jpg Reading : IMG_20160323_160645.jpg Reading : IMG_20160323_160734.jpg Reading : IMG_20160323_160742.jpg Reading : VID_20160323_160748.mp4 Reading : VID_20160323_160841.mp4 Reading : VID_20160323_160847.mp4 Reading : VID_20160323_160906.mp4 Reading : VID_20160323_161029.mp4 Reading : VID_20160323_161037.mp4 Reading : VID_20160323_161116.mp4 Reading : IMG_20160323_183729.jpg Reading : IMG_20160323_183752.jpg Reading : IMG_20160323_183851.jpg Reading : IMG_20160323_183855.jpg Reading : IMG_20160323_183906.jpg Reading : IMG_20160323_183909.jpg Reading : IMG_20160323_183918.jpg Reading : IMG_20160323_184028.jpg Reading : IMG_20160323_184036.jpg Reading : IMG_20160323_184058.jpg Reading : IMG_20160323_191347.jpg Reading : IMG_20160323_191359.jpg Reading : IMG_20160323_191403.jpg Reading : IMG_20160324_090638.jpg Reading : IMG_20160324_090642.jpg Reading : IMG_20160401_115607.jpg Reading : IMG_20160324_130205.jpg Reading : IMG_20160324_130230.jpg Reading : IMG_20160401_115612.jpg Reading : IMG_20160401_115616.jpg Reading : IMG_20160401_115627.jpg Reading : IMG_20160324_131848.jpg Reading : IMG_20160401_115632.jpg Reading : IMG_20160401_120710.jpg Reading : IMG_20160401_120902.jpg Reading : IMG_20160401_120908.jpg Reading : IMG_20160401_120914.jpg Reading : IMG_20160401_120920.jpg Reading : IMG_20160401_120927.jpg Reading : IMG_20160401_120945.jpg Reading : IMG_20160401_121005.jpg Reading : IMG_20160401_121101.jpg Reading : IMG_20160401_121125.jpg Reading : IMG_20160401_121141.jpg Reading : IMG_20160401_121147.jpg Reading : IMG_20160401_121157.jpg Reading : IMG_20160401_121213.jpg Reading : IMG_20160401_121224.jpg Reading : IMG_20160401_121241_HDR.jpg Reading : IMG_20160401_121249_HDR.jpg Reading : IMG_20160401_121325.jpg Reading : IMG_20160325_103800.jpg Reading : IMG_20160401_121336.jpg Reading : IMG_20160401_121404.jpg Reading : IMG_20160401_121411.jpg Reading : IMG_20160401_121418.jpg Reading : IMG_20160401_121424.jpg Reading : IMG_20160401_121445.jpg Reading : IMG_20160401_121450.jpg Reading : IMG_20160401_121517.jpg Reading : IMG_20160401_121522.jpg Reading : IMG_20160401_121528.jpg Reading : IMG_20160401_121534.jpg Reading : IMG_20160401_121541.jpg Reading : IMG_20160401_121553.jpg Reading : IMG_20160401_121601.jpg Reading : IMG_20160401_121608.jpg Reading : IMG_20160401_121628.jpg Reading : IMG_20160401_121635.jpg Reading : IMG_20160401_121641.jpg Reading : IMG_20160401_121645.jpg Reading : IMG_20160401_121658.jpg Reading : IMG_20160401_121704.jpg Reading : IMG_20160401_121710.jpg Reading : IMG_20160401_121715.jpg Reading : IMG_20160401_121723.jpg Reading : IMG_20160401_121743.jpg Reading : IMG_20160401_121746.jpg Reading : IMG_20160401_121754.jpg Reading : IMG_20160401_121807.jpg Reading : IMG_20160401_121816.jpg Reading : IMG_20160401_121830.jpg Reading : IMG_20160401_121909.jpg Reading : IMG_20160401_121915.jpg Reading : IMG_20160401_121921.jpg Reading : IMG_20160401_121935.jpg Reading : IMG_20160401_121940.jpg Reading : IMG_20160401_121954.jpg Reading : IMG_20160401_122001.jpg Reading : IMG_20160401_122009.jpg Reading : IMG_20160401_122036.jpg Reading : IMG_20160401_122045.jpg Reading : IMG_20160401_122056.jpg Reading : IMG_20160401_122101.jpg Reading : IMG_20160401_122106.jpg Reading : IMG_20160401_122109.jpg Reading : IMG_20160401_122114.jpg Reading : IMG_20160401_122118.jpg Reading : IMG_20160401_122128.jpg Reading : IMG_20160401_122136.jpg Reading : IMG_20160401_122144.jpg Reading : IMG_20160401_122150.jpg Reading : IMG_20160401_122154.jpg Reading : IMG_20160401_123924.jpg Reading : IMG_20160401_123930.jpg Reading : IMG_20160401_123935.jpg Reading : VID_20160401_124052.mp4 Reading : IMG_20160325_211311.jpg Reading : IMG_20160325_211318.jpg Reading : IMG_20160325_211325.jpg Reading : IMG_20160325_211330.jpg Reading : IMG_20160315_205935.jpg Reading : IMG_20160315_205957.jpg Reading : VID_20160315_210120.mp4 Reading : IMG_20160325_211334.jpg Reading : IMG_20160325_211340.jpg Reading : VID_20160325_212007.mp4 Reading : VID_20160316_112540.mp4 Reading : VID_20160316_112705.mp4 Reading : IMG_20160316_112930.jpg Reading : IMG_20160316_113026.jpg Reading : IMG_20160316_154332_HDR.jpg Reading : IMG_20160316_154354_HDR.jpg Reading : IMG_20160316_154413.jpg Reading : IMG_20160326_163414.jpg Reading : IMG_20160326_163536.jpg Reading : IMG_20160326_163639.jpg Reading : VID_20160326_163644.mp4 Reading : IMG_20160316_154455.jpg Reading : IMG_20160316_154500.jpg Reading : VID_20160326_170304.mp4 Reading : IMG_20160326_170335.jpg Reading : IMG_20160326_170342.jpg Reading : IMG_20160326_170352.jpg Reading : IMG_20160326_170401.jpg Reading : IMG_20160326_170408.jpg Reading : IMG_20160326_170416.jpg Reading : IMG_20160326_170427.jpg Reading : IMG_20160316_154651.jpg Reading : IMG_20160316_154656.jpg Reading : IMG_20160326_170432.jpg Reading : IMG_20160326_170443.jpg Reading : IMG_20160326_170456.jpg Reading : IMG_20160326_170502.jpg Reading : IMG_20160326_170511.jpg Reading : IMG_20160326_170620.jpg Reading : IMG_20160316_154734.jpg Reading : IMG_20160316_154759_HDR.jpg Reading : IMG_20160326_170634.jpg Reading : IMG_20160326_180905.jpg Reading : IMG_20160326_180911.jpg Reading : IMG_20160326_180931.jpg Reading : IMG_20160326_180947.jpg Reading : IMG_20160326_181008.jpg Reading : IMG_20160326_184400.jpg Reading : IMG_20160326_184404.jpg Reading : VID_20160326_211334.mp4 Reading : VID_20160316_165220.mp4 Reading : VID_20160316_212252.mp4 Reading : VID_20160316_212307.mp4 Reading : VID_20160316_212724.mp4 Reading : VID_20160326_211507.mp4 Reading : IMG_20160317_083038.jpg Reading : IMG_20160317_110244.jpg Reading : IMG_20160317_110331.jpg Reading : IMG_20160317_110338.jpg Reading : IMG_20160317_110343.jpg Reading : IMG_20160317_110446.jpg Reading : IMG_20160317_110450.jpg Reading : IMG_20160317_110454.jpg Reading : IMG_20160317_110517.jpg Reading : IMG_20160317_110522.jpg Reading : IMG_20160317_110526.jpg Reading : IMG_20160317_110651.jpg Reading : IMG_20160317_110709.jpg Reading : IMG_20160317_110755.jpg Reading : IMG_20160317_110801.jpg Reading : IMG_20160317_110810.jpg Reading : IMG_20160317_110852.jpg Reading : IMG_20160317_110856.jpg Reading : IMG_20160317_110859.jpg Reading : IMG_20160317_110946.jpg Reading : IMG_20160317_110951.jpg Reading : IMG_20160317_111445.jpg Reading : IMG_20160317_111450.jpg Reading : IMG_20160317_111500.jpg Reading : IMG_20160317_111508.jpg Reading : IMG_20160317_111513.jpg Reading : IMG_20160317_111600.jpg Reading : IMG_20160317_111605.jpg Reading : VID_20160317_111630.mp4 Reading : VID_20160317_113012.mp4 Reading : IMG_20160317_113028.jpg Reading : IMG_20160317_113035.jpg Reading : IMG_20160317_113059.jpg Reading : IMG_20160317_113102.jpg Reading : IMG_20160317_113227.jpg Reading : IMG_20160317_113236.jpg Reading : IMG_20160317_113350.jpg Reading : IMG_20160317_113629.jpg Reading : IMG_20160319_110620.jpg Reading : IMG_20160318_145130.jpg Reading : IMG_20160318_145136.jpg Reading : IMG_20160318_145140.jpg Reading : IMG_20160318_145154.jpg Reading : IMG_20160318_145159.jpg Reading : IMG_20160319_110625.jpg Reading : IMG_20160319_110703.jpg Reading : IMG_20160319_110709.jpg Reading : VID_20160320_185242.mp4 Reading : VID_20160320_185658.mp4 Reading : IMG_20160320_190548.jpg Reading : IMG_20160320_190605.jpg Reading : IMG_20160320_192246.jpg Reading : IMG_20160320_192256.jpg Reading : IMG_20160320_192419.jpg Reading : IMG_20160320_192427.jpg Reading : IMG_20160320_192438.jpg Reading : IMG_20160320_192531.jpg Reading : IMG_20160320_192547.jpg Reading : IMG_20160320_192555.jpg Reading : IMG_20160320_192604.jpg Reading : IMG_20160320_192611.jpg Reading : IMG_20160320_192622.jpg Reading : IMG_20160320_192645.jpg Reading : IMG_20160320_192706.jpg Reading : IMG_20160320_192726.jpg Reading : IMG_20160320_192909.jpg Reading : IMG_20160320_192923.jpg Reading : IMG_20160320_192928.jpg Reading : IMG_20160320_192942.jpg Reading : IMG_20160320_192947.jpg Reading : IMG_20160320_192953.jpg Reading : IMG_20160320_193002.jpg Reading : IMG_20160320_193008.jpg Reading : IMG_20160320_194758.jpg Reading : VID_20160320_195414.mp4 Reading : VID_20160320_195911.mp4 Reading : VID_20160320_195921.mp4 Reading : VID_20160320_200253.mp4 Reading : VID_20160320_200333.mp4 Reading : VID_20160320_200442.mp4 Reading : IMG_20160320_200527.jpg Reading : IMG_20160320_200532.jpg Reading : IMG_20160319_110625~2.jpg Reading : IMG_20160328_222031.jpg Reading : IMG_20160328_222037.jpg Reading : IMG_20160328_222545.jpg Reading : IMG_20160328_222551.jpg Reading : IMG_20160328_222556.jpg Reading : IMG_20160328_222601.jpg Reading : IMG_20160330_123822.jpg Reading : VID_20160329_184354.mp4 Read Ok, total read : 1527 MiB Data Saved to : C:\InfinityBox\CM2MTK\Read_out\MT6592___90014A4838473264040501898B5961DF\ Done! Elapsed: 00:15:58 Reconnect Power/Cable! now flash and set goes dead Code: Scatter Load Ok , BaseBand : MT6592 , Project : lcsh92_wet_jb9 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.44 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040501898B5961DF Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501898B5961DF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 4B540D89054482367F1DD8C530A22A05 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6592 , Project : lcsh92_wet_jb9 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : Undefined structure, determined as forced BL : eMMC supported by BootLoader! BL : BatteryLevel : 3850 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000000000-0x0000000000100000 Erase : 0x0000000001D00000-0x0000000097F00000 Flash Pre-Erase Done, time used : 00:00:09 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_lcsh92_wet_jb9.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:08 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:02:38 Reconnect Power/Cable! Operation : Check / Read Info [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 66 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040501898B5961DF Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501898B5961DF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 4B540D89054482367F1DD8C530A22A05 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! SECURITY : IMEI_SW [1] : 865291021------ IMEI_SW [2] : 865291021------ BTMAC Addr : 0C1DAF3679D3 WiFi MAC : 0C1DAF7679D0 Done! Elapsed: 00:00:11 Reconnect Power/Cable! repair preloader but fail Code: User selected Preloader file : preloader_lcsh92_wet_jb9.bin Operation : Init Preloader [ v1.44 ] Supported HW by Preloader : FlashID [0] CID : 000000000000000000 , Name : FlashID [1] CID : 000000000000000000 , Name : FlashID [2] CID : 000000000000000000 , Name : 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040501898B5961DF Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501898B5961DF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 4B540D89054482367F1DD8C530A22A05 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SecCfg Passed , 1799 BL : BBID supported by BootLoader! Supported HW by Preloader : FlashID [0] CID : 000000000000000000 , Name : FlashID [1] CID : 000000000000000000 , Name : FlashID [2] CID : 000000000000000000 , Name : STORAGE : BL NOT support this eMMC! Select Correct One! Done! Elapsed: 00:00:08 Reconnect Power/Cable! Code: Operation : Flash Erase [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040501898B5961DF Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501898B5961DF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 4B540D89054482367F1DD8C530A22A05 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Erase Flash now ... Erase whole flash Flash erase done Done! Elapsed: 00:00:17 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6592 , Project : lcsh92_wet_jb9 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.44 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040501898B5961DF Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501898B5961DF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 4B540D89054482367F1DD8C530A22A05 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6592 , Project : lcsh92_wet_jb9 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : Undefined structure, determined as forced BL : eMMC supported by BootLoader! BL : BatteryLevel : 3793 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000000000-0x0000000000100000 Erase : 0x0000000001D00000-0x00000001CEE00000 Flash Pre-Erase Done, time used : 00:00:09 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_lcsh92_wet_jb9.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : FFFFFFFF PartErr : Not initialized , will update PMT now ... Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:01:05 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:01:31 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6592 , Project : lcsh92_wet_jb9 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.44 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040501898B5961DF Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501898B5961DF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 4B540D89054482367F1DD8C530A22A05 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6592 , Project : lcsh92_wet_jb9 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : Undefined structure, determined as forced BL : eMMC supported by BootLoader! BL : BatteryLevel : 3791 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000000000-0x0000000000100000 Erase : 0x0000000001D00000-0x0000000097F00000 Flash Pre-Erase Done, time used : 00:00:07 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_lcsh92_wet_jb9.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : FFFFFFFF PartErr : Not initialized , will update PMT now ... Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:05:04 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:05:27 Reconnect Power/Cable! Operation : Check / Read Info [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040501898B5961DF Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501898B5961DF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 4B540D89054482367F1DD8C530A22A05 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done :( Erased phone or unsupported FlashIc? Done! Elapsed: 00:00:03 Reconnect Power/Cable! |
The Following User Says Thank You to rehmani For This Useful Post: |
04-05-2016, 16:30 | #3 (permalink) |
Freak Poster Join Date: Mar 2008 Location: MX-KEY is the BEST NOKIA TOOL
Member: 716661 Status: Offline Thanks Meter: 19 | have u solved ur problem....?? coz my redmi note hard brick after flashing with sp flash tool...and now not starting and even not show charging ... have tried many firmware from miui forum....but still result is same.. any one faced same problem? pl help... |
04-06-2016, 05:11 | #5 (permalink) | |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | Quote:
============ Memory Detection Report =========== Internal RAM: External RAM: Type = DRAM Size = 0x80000000 (2048MB/16384Mb) NAND Flash: ERROR: NAND Flash was not detected! EMMC: EMMC_PART_BOOT1 Size = 0x0000000000400000(4MB) EMMC_PART_BOOT2 Size = 0x0000000000400000(4MB) EMMC_PART_RPMB Size = 0x0000000000400000(4MB) EMMC_PART_GP1 Size = 0x0000000000000000(0MB) EMMC_PART_GP2 Size = 0x0000000000000000(0MB) EMMC_PART_GP3 Size = 0x0000000000000000(0MB) EMMC_PART_GP4 Size = 0x0000000000000000(0MB) EMMC_PART_USER Size = 0x00000001d2000000(7456MB) ============ RAM Test ============ Data Bus Test: [D0] [D1] [D2] [D3] [D4] [D5] [D6] [D7] [D8] [D9] [D10] [D11] [D12] [D13] [D14] [D15] [D16] [D17] [D18] [D19] [D20] [D21] [D22] [D23] [D24] [D25] [D26] [D27] [D28] [D29] [D30] [D31] OK!! Address Bus Test: [A1] [A2] [A3] [A4] [A5] [A6] [A7] [A8] [A9] [A10] [A11] [A12] [A13] [A14] [A15] [A16] [A17] [A18] [A19] [A20] [A21] [A22] [A23] [A24] [A25] [A26] [A27] [A28] [A29] [A30] OK!! RAM Pattern Test : Writing ... 0x44332211, 0xA5A5A5A5, 0xA5A5A500, 0xA500A500, 0xA5000000, 0x00000000, 0xFFFF0000, 0xFFFFFFFF, OK!! Increment/Decrement Test: Writing... OK!! | |
04-06-2016, 05:51 | #6 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
04-06-2016, 05:53 | #7 (permalink) |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Have you use this file - http://bigota.d.miui.com/V7.0.2.0.KH...5c7b784c27.tgz ??? If not use & post result Br - srinibas |
The Following 3 Users Say Thank You to srinibas For This Useful Post: |
04-06-2016, 07:05 | #10 (permalink) | |
04-06-2016, 07:31 | #11 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,421 | Quote:
The Following User Says Thank You to Kirumira For This Useful Post: |
04-07-2016, 06:46 | #13 (permalink) | |
no not get | |
04-07-2016, 11:21 | #15 (permalink) | |
No Life Poster Join Date: Aug 2012 Location: Bali-Indonesia
Member: 1800628 Status: Offline Thanks Meter: 941 | Quote:
The Following User Says Thank You to Deni's For This Useful Post: |
