Old 06-14-2017, 12:28   #1 (permalink)
Member: 2157664
Thanks Meter: 43
Remove MI5 Mi account
Hello!
I have one MI5 with MI account, I reset it with infinity but when I connect to wifi the phone blocks itself. What can I do?
Thanks!
Old 06-14-2017, 12:44   #2 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 735
Disable mi app
Or
Rebuild your imei with 1 number change
Old 06-14-2017, 13:02   #3 (permalink)
Member: 2157664
Thanks Meter: 43
the phone has locked bootloader, I can t root it or to change imei. is there any box or dongle thats changes imei in edl mode? thanks!
Old 06-14-2017, 17:48   #4 (permalink)
Member: 2157664
Thanks Meter: 43
any idea anyone? thanks!
Old 06-14-2017, 17:55   #5 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
That not help.
Solution explained already dozen of times - downgrade to older version as possible and repeat reset, then login/out from account.
The Following User Says Thank You to JayDi For This Useful Post:
Old 06-15-2017, 14:08   #6 (permalink)
Member: 2157664
Thanks Meter: 43
I did this allready, I put MIUI 7.2.4.0, the oldest I can find but after connecting to wifi, the phone blocks.
Old 06-15-2017, 14:27   #7 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 517
downgrade is not solution use umt disable mi acc this option cm2 not support
The Following User Says Thank You to SAJONDUTTA For This Useful Post:
Old 06-15-2017, 14:41   #8 (permalink)
JayDi's Avatar
Member: 462970
Please, my dear slow friend, next time check where you posting and what you posting. Last warning. Lick somewhere else, not here.
Then you should try use custom ROM, for example.
Or repeat reset try few times. When power on phone - connect to wifi, register new acc and out from it.
Old 06-15-2017, 15:02   #9 (permalink)
Member: 2157664
Thanks Meter: 43
custom rom means to unlock the boot and I can t do that because I have to connect to wifi and put my own account.
Old 06-15-2017, 15:03   #10 (permalink)
Member: 2157664
Thanks Meter: 43
I guess I need to change imei because the phone is identify by server from imei.
Old 06-15-2017, 15:05   #11 (permalink)
JayDi's Avatar
Member: 462970
Completely wrong. It change nothing.
Old 06-15-2017, 18:52   #12 (permalink)
Member: 2157664
Thanks Meter: 43
Or I neet root to remove the application that communicates with xiaomi server?
Old 06-15-2017, 19:14   #13 (permalink)
JayDi's Avatar
Member: 462970
I can add direct Micloud disable without root in edl mode.
Not sure how new sw version will react on this, will check in near few days.
The Following 4 Users Say Thank You to JayDi For This Useful Post:
Old 06-19-2017, 11:31   #14 (permalink)
Member: 599694
Thanks Meter: 76
It will be very good! Disable\freeze this nasty finddevice.apk
Old 07-24-2017, 12:53   #15 (permalink)
Member: 2686627
Thanks Meter: 2
me too for this prob for mi5 after make step by step when i conect wifi account lock again
Page generated in 0.16976 seconds with 8 queries
