Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2013
Member: 1933548 Status: Offline Thanks Meter: 19 | reno3 not boot with 2.21 update please give me the correct steps Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : CB30E214B8FCD1F680CD77CDF113E3CD04FA955F01FDDFC941 5B44B977415F9C AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
![]() | #3 (permalink) |
Member: 1933548 Status: Offline Thanks Meter: 19 | already tried but not done Operation : HW Report [ v2.21 ] HWreport : Mode : UFS 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN RAPHAEL BROM : MEID : 6C0A032B0442DF619448A0407A97EADF BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : CB30E214B8FCD1F680CD77CDF113E3CD04FA955F01FDDFC941 5B44B977415F9C BROM : SLA : Local Auth Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Info : LEGACY : HW reporting feature unavailable for current device! Done! Elapsed: 00:00:04 |
![]() | #4 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2011 Location: Jhapa,Nepal
Member: 1626780 Status: Offline Thanks Meter: 1,043 | Quote:
repeat operation again don't forget to tick SSLA | |
![]() | #6 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2014 Location: NIGERIA
Member: 2156069 Status: Offline Thanks Meter: 64 | reno3 Quote:
reno 3, tick sSLA and select mt6779_gen in oppo section. Last edited by merujeffrey; 02-01-2021 at 18:48. Reason: typo error | |
The Following User Says Thank You to merujeffrey For This Useful Post: |
![]() | #7 (permalink) | |
Member: 2156069 Status: Offline Thanks Meter: 64 | Quote:
![]() | #9 (permalink) |
Member: 1933548 Status: Offline Thanks Meter: 19 | thanks to all. the problem was with the driver Operation : HW Report [ v2.21 ] HWreport : Mode : UFS 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM19) MODE : BOOTROM PORT : 19 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN RAPHAEL BROM : MEID : 6C0A032B0442DF619448A0407A97EADF BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : MT6779_GEN | Manual : Disabled BROM : SOCID : CB30E214B8FCD1F680CD77CDF113E3CD04FA955F01FDDFC941 5B44B977415F9C BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_oppo6779.bin EMI : CNT : 000D EMI : [00] : eUFS : LP_DDR4X : DEV : KM2V7001CM-B706 : RAM : [ 6.00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM8V7001JA-B813 : RAM : [ 8.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4.00 GB ] EMI : [03] : eUFS : LP_DDR4X : DEV : H9HQ16AECMMDAR : RAM : [ 6.00 GB ] EMI : [04] : eUFS : LP_DDR4X : DEV : KM5V7001DM-B621 : RAM : [ 4.00 GB ] EMI : [05] : eUFS : LP_DDR4X : DEV : KM2B8001CM-BB01 : RAM : [ 6.00 GB ] EMI : [06] : eUFS : LP_DDR4X : DEV : KM8V7001JM-B810 : RAM : [ 8.00 GB ] EMI : [07] : eUFS : LP_DDR4X : DEV : KM8B8001JM-BC01 : RAM : [ 8.00 GB ] EMI : [08] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8.00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8.00 GB ] EMI : [0A] : eUFS : LP_DDR4X : DEV : H9HQ22AECMMDAR : RAM : [ 6.00 GB ] EMI : [0B] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6.00 GB ] EMI : [0C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: CE014B4D3856383030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V8001JM-B81 IFW : 1000 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 00340031006100390066006100650063 REG : 0x101010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 588B9BF3A0EB69EC9C08DE064A0E8BBC DA : USB : HIGH-SPEED Boot done! Memory Info : CID : KM8V8001JM-B813 EXT_CSD Info : [UFS] Device Desc: [UFS] String Desc: Serial Number INDEX 2, LENGTH 24 [UFS] Serial Number: 003400310061003900660061006500630066006300310064 [UFS] life cycle check, pre_eol_info=1, life_time_est_a=1, life_time_est_b=1 [UFS] vendor id : 0x1ce [UFS] ufs id : KM8V8001JM-B813 [UFS] ufs fwver: 1000 [UFS] dev_quirk = 0x0 [UFS] Custom force provison=0, TW size=-1GB, TW no red=1, HPB size=-1GB [UFS] info: number of active LU: 3, check OK. [UFS] info: number of Boot LU: 2, check OK. [UFS] info: LU Configuration Check OK. Bootable UFS [UFS] info: Boot LU Configuration Check OK. Active Boot LU: LU0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] info: HS-G3-2 Overall status : MLC status : 0% - 10% used SLC status : 0% - 10% used EOL status : Normal ( Less than 80% reserved blocks used ) RPMB : RPMB KEY NOT set! [State : CLEAN : USABLE] Done! Elapsed: 00:00:21 Operation : Reset Settings/Format FS [ v2.21 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM19) MODE : BOOTROM PORT : 19 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN RAPHAEL BROM : MEID : 6C0A032B0442DF619448A0407A97EADF BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : MT6779_GEN | Manual : Disabled BROM : SOCID : CB30E214B8FCD1F680CD77CDF113E3CD04FA955F01FDDFC941 5B44B977415F9C BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_oppo6779.bin EMI : CNT : 000D EMI : [00] : eUFS : LP_DDR4X : DEV : KM2V7001CM-B706 : RAM : [ 6.00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM8V7001JA-B813 : RAM : [ 8.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4.00 GB ] EMI : [03] : eUFS : LP_DDR4X : DEV : H9HQ16AECMMDAR : RAM : [ 6.00 GB ] EMI : [04] : eUFS : LP_DDR4X : DEV : KM5V7001DM-B621 : RAM : [ 4.00 GB ] EMI : [05] : eUFS : LP_DDR4X : DEV : KM2B8001CM-BB01 : RAM : [ 6.00 GB ] EMI : [06] : eUFS : LP_DDR4X : DEV : KM8V7001JM-B810 : RAM : [ 8.00 GB ] EMI : [07] : eUFS : LP_DDR4X : DEV : KM8B8001JM-BC01 : RAM : [ 8.00 GB ] EMI : [08] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8.00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8.00 GB ] EMI : [0A] : eUFS : LP_DDR4X : DEV : H9HQ22AECMMDAR : RAM : [ 6.00 GB ] EMI : [0B] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6.00 GB ] EMI : [0C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: CE014B4D3856383030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V8001JM-B81 IFW : 1000 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 00340031006100390066006100650063 REG : 0x101010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 588B9BF3A0EB69EC9C08DE064A0E8BBC DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:36 Reconnect Power/Cable! |
The Following 6 Users Say Thank You to [email protected] For This Useful Post: |
![]() | #10 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2010
Member: 1356561 Status: Offline Thanks Meter: 408 | Operation : Reset Settings/Format FS [ v2.21 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM13) MODE : BOOTROM PORT : 13 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : MEID : D23C0A1E555C49D2FEBC15E1FC8E076A BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BOOTROM BROM : LOG : F0: 102B 0000 F3: 1001 0000 [0200] F3: 1001 0000 F7: 0000 0000 V0: 0000 0000 [0001] BROM : SOCID : A0F872D682005D7BF94D998CCF0B84AFD5E9B477AC1124E4FD 399D7144EFCC39 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6779 AP_SWTM : Mon Apr 27 03:42:45 CST 2020 AP_SWVR : CPH1945_11_A.23_200427_ef8ca3a3 Format Ok : UserData - > Format in META will NOT reset FRP! Done! Elapsed: 00:00:45 Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.21 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM13) MODE : BOOTROM PORT : 13 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN RAPHAEL BROM : MEID : D23C0A1E555C49D2FEBC15E1FC8E076A BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : MT6779_GEN | Manual : Disabled BROM : SOCID : A0F872D682005D7BF94D998CCF0B84AFD5E9B477AC1124E4FD 399D7144EFCC39 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_oppo6779.bin EMI : CNT : 000D EMI : [00] : eUFS : LP_DDR4X : DEV : KM2V7001CM-B706 : RAM : [ 6,00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM8V7001JA-B813 : RAM : [ 8,00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4,00 GB ] EMI : [03] : eUFS : LP_DDR4X : DEV : H9HQ16AECMMDAR : RAM : [ 6,00 GB ] EMI : [04] : eUFS : LP_DDR4X : DEV : KM5V7001DM-B621 : RAM : [ 4,00 GB ] EMI : [05] : eUFS : LP_DDR4X : DEV : KM2B8001CM-BB01 : RAM : [ 6,00 GB ] EMI : [06] : eUFS : LP_DDR4X : DEV : KM8V7001JM-B810 : RAM : [ 8,00 GB ] EMI : [07] : eUFS : LP_DDR4X : DEV : KM8B8001JM-BC01 : RAM : [ 8,00 GB ] EMI : [08] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8,00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8,00 GB ] EMI : [0A] : eUFS : LP_DDR4X : DEV : H9HQ22AECMMDAR : RAM : [ 6,00 GB ] EMI : [0B] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6,00 GB ] EMI : [0C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6,00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512,00 KB ] DRAM: 0x200000000 [ 8,00 GB ] UFS: CE014B4D3842383030314A4D2D424330 UFS: VEN : 0x01CE VID : KM8B8001JM-BC0 IFW : 0600 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0x3B96000000 [ 238,34 GB ] FSN : 00330036003400330034006100360064 REG : 0x101010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A79E35492488070F7020922E6AA8A35 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:01:10 Reconnect Power/Cable! Operation : Read Security [ v2.21 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM13) MODE : BOOTROM PORT : 13 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN RAPHAEL BROM : MEID : D23C0A1E555C49D2FEBC15E1FC8E076A BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : MT6779_GEN | Manual : Disabled BROM : SOCID : A0F872D682005D7BF94D998CCF0B84AFD5E9B477AC1124E4FD 399D7144EFCC39 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_oppo6779.bin EMI : CNT : 000D EMI : [00] : eUFS : LP_DDR4X : DEV : KM2V7001CM-B706 : RAM : [ 6,00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM8V7001JA-B813 : RAM : [ 8,00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4,00 GB ] EMI : [03] : eUFS : LP_DDR4X : DEV : H9HQ16AECMMDAR : RAM : [ 6,00 GB ] EMI : [04] : eUFS : LP_DDR4X : DEV : KM5V7001DM-B621 : RAM : [ 4,00 GB ] EMI : [05] : eUFS : LP_DDR4X : DEV : KM2B8001CM-BB01 : RAM : [ 6,00 GB ] EMI : [06] : eUFS : LP_DDR4X : DEV : KM8V7001JM-B810 : RAM : [ 8,00 GB ] EMI : [07] : eUFS : LP_DDR4X : DEV : KM8B8001JM-BC01 : RAM : [ 8,00 GB ] EMI : [08] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8,00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8,00 GB ] EMI : [0A] : eUFS : LP_DDR4X : DEV : H9HQ22AECMMDAR : RAM : [ 6,00 GB ] EMI : [0B] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6,00 GB ] EMI : [0C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6,00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512,00 KB ] DRAM: 0x200000000 [ 8,00 GB ] UFS: CE014B4D3842383030314A4D2D424330 UFS: VEN : 0x01CE VID : KM8B8001JM-BC0 IFW : 0600 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0x3B96000000 [ 238,34 GB ] FSN : 00330036003400330034006100360064 REG : 0x101010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A79E35492488070F7020922E6AA8A35 DA : USB : HIGH-SPEED Boot done! NVRAM check : Failed! NVRAM damaged! NVRAM : SEC ENCRYPT [ IMEI ENCRYPTED ] NVM saved as : MT6779__UFS__.mt_sec NVM saved to : C:\Users\hp\Desktop\ Done! Elapsed: 00:01:01 Reconnect Power/Cable! Operation : HW Report [ v2.21 ] HWreport : Mode : UFS 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM13) MODE : BOOTROM PORT : 13 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN RAPHAEL BROM : MEID : D23C0A1E555C49D2FEBC15E1FC8E076A BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : MT6779_GEN | Manual : Disabled BROM : SOCID : A0F872D682005D7BF94D998CCF0B84AFD5E9B477AC1124E4FD 399D7144EFCC39 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_oppo6779.bin EMI : CNT : 000D EMI : [00] : eUFS : LP_DDR4X : DEV : KM2V7001CM-B706 : RAM : [ 6,00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM8V7001JA-B813 : RAM : [ 8,00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4,00 GB ] EMI : [03] : eUFS : LP_DDR4X : DEV : H9HQ16AECMMDAR : RAM : [ 6,00 GB ] EMI : [04] : eUFS : LP_DDR4X : DEV : KM5V7001DM-B621 : RAM : [ 4,00 GB ] EMI : [05] : eUFS : LP_DDR4X : DEV : KM2B8001CM-BB01 : RAM : [ 6,00 GB ] EMI : [06] : eUFS : LP_DDR4X : DEV : KM8V7001JM-B810 : RAM : [ 8,00 GB ] EMI : [07] : eUFS : LP_DDR4X : DEV : KM8B8001JM-BC01 : RAM : [ 8,00 GB ] EMI : [08] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8,00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8,00 GB ] EMI : [0A] : eUFS : LP_DDR4X : DEV : H9HQ22AECMMDAR : RAM : [ 6,00 GB ] EMI : [0B] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6,00 GB ] EMI : [0C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6,00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512,00 KB ] DRAM: 0x200000000 [ 8,00 GB ] UFS: CE014B4D3842383030314A4D2D424330 UFS: VEN : 0x01CE VID : KM8B8001JM-BC0 IFW : 0600 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0x3B96000000 [ 238,34 GB ] FSN : 00330036003400330034006100360064 REG : 0x101010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A79E35492488070F7020922E6AA8A35 DA : USB : HIGH-SPEED Boot done! Memory Info : CID : KM8B8001JM-BC01 EXT_CSD Info : [UFS] Device Desc: [UFS] String Desc: Serial Number INDEX 2, LENGTH 24 [UFS] Serial Number: 003300360034003300340061003600640031006300310064 [UFS] life cycle check, pre_eol_info=1, life_time_est_a=1, life_time_est_b=1 [UFS] vendor id : 0x1ce [UFS] ufs id : KM8B8001JM-BC01 [UFS] ufs fwver: 0600 [UFS] dev_quirk = 0x0 [UFS] Custom force provison=0, TW size=-1GB, TW no red=1, HPB size=-1GB [UFS] info: number of active LU: 3, check OK. [UFS] info: number of Boot LU: 2, check OK. [UFS] info: LU Configuration Check OK. Bootable UFS [UFS] info: Boot LU Configuration Check OK. Active Boot LU: LU0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] warn: Power on, reset, or bus device reset occupied [UFS] Sense Data: ASC=29, ASCQ=0 [UFS] info: HS-G3-2 Overall status : MLC status : 0% - 10% used SLC status : 0% - 10% used EOL status : Normal ( Less than 80% reserved blocks used ) RPMB : RPMB KEY NOT set! [State : CLEAN : USABLE] Done! Elapsed: 00:00:40 Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM13) MODE : BOOTROM PORT : 13 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN RAPHAEL BROM : MEID : D23C0A1E555C49D2FEBC15E1FC8E076A BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : MT6779_GEN | Manual : Disabled BROM : SOCID : A0F872D682005D7BF94D998CCF0B84AFD5E9B477AC1124E4FD 399D7144EFCC39 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_oppo6779.bin EMI : CNT : 000D EMI : [00] : eUFS : LP_DDR4X : DEV : KM2V7001CM-B706 : RAM : [ 6,00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM8V7001JA-B813 : RAM : [ 8,00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4,00 GB ] EMI : [03] : eUFS : LP_DDR4X : DEV : H9HQ16AECMMDAR : RAM : [ 6,00 GB ] EMI : [04] : eUFS : LP_DDR4X : DEV : KM5V7001DM-B621 : RAM : [ 4,00 GB ] EMI : [05] : eUFS : LP_DDR4X : DEV : KM2B8001CM-BB01 : RAM : [ 6,00 GB ] EMI : [06] : eUFS : LP_DDR4X : DEV : KM8V7001JM-B810 : RAM : [ 8,00 GB ] EMI : [07] : eUFS : LP_DDR4X : DEV : KM8B8001JM-BC01 : RAM : [ 8,00 GB ] EMI : [08] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8,00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8,00 GB ] EMI : [0A] : eUFS : LP_DDR4X : DEV : H9HQ22AECMMDAR : RAM : [ 6,00 GB ] EMI : [0B] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6,00 GB ] EMI : [0C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6,00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512,00 KB ] DRAM: 0x200000000 [ 8,00 GB ] UFS: CE014B4D3842383030314A4D2D424330 UFS: VEN : 0x01CE VID : KM8B8001JM-BC0 IFW : 0600 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0x3B96000000 [ 238,34 GB ] FSN : 00330036003400330034006100360064 REG : 0x101010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A79E35492488070F7020922E6AA8A35 DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-05-05 Product Manfct : OPPO Build Time : 26.04.2020 Product Brand : OPPO Product Model : CPH1945 Product Info : CPH1945 Product Name : CPH1945 Product Device : OP4B65 SW OTA Version : CPH1945PUEX_11.A.23_0230_202004270300 Display ID : CPH1945EX_11_A.23 Display ID : CPH1945EX_11_A.23_200427 Kernel Info : 4.9.117 Backup sensetive data [ 15 ] Backup path : Backup\MT6779__A79E35492488070F07020922E6AA8A35\ [21] Read : NVRAM [13] Read : NVDATA [20] Read : PROINFO [35] Read : LK [12] Read : NVCFG [15] Read : PROTECT1 [16] Read : PROTECT2 [18] Read : PERSIST [0] Read : PRELOADER [17] Read : SECCFG [5] Read : OPPORESERVE1 [6] Read : OPPORESERVE2 [7] Read : OPPORESERVE3 Backup done! STORAGE : LifeStatus : UFS : OK! Done! Elapsed: 00:00:48 Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM13) MODE : BOOTROM PORT : 13 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN RAPHAEL BROM : MEID : D23C0A1E555C49D2FEBC15E1FC8E076A BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : MT6779_GEN | Manual : Disabled BROM : SOCID : A0F872D682005D7BF94D998CCF0B84AFD5E9B477AC1124E4FD 399D7144EFCC39 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_oppo6779.bin EMI : CNT : 000D EMI : [00] : eUFS : LP_DDR4X : DEV : KM2V7001CM-B706 : RAM : [ 6,00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM8V7001JA-B813 : RAM : [ 8,00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4,00 GB ] EMI : [03] : eUFS : LP_DDR4X : DEV : H9HQ16AECMMDAR : RAM : [ 6,00 GB ] EMI : [04] : eUFS : LP_DDR4X : DEV : KM5V7001DM-B621 : RAM : [ 4,00 GB ] EMI : [05] : eUFS : LP_DDR4X : DEV : KM2B8001CM-BB01 : RAM : [ 6,00 GB ] EMI : [06] : eUFS : LP_DDR4X : DEV : KM8V7001JM-B810 : RAM : [ 8,00 GB ] EMI : [07] : eUFS : LP_DDR4X : DEV : KM8B8001JM-BC01 : RAM : [ 8,00 GB ] EMI : [08] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8,00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8,00 GB ] EMI : [0A] : eUFS : LP_DDR4X : DEV : H9HQ22AECMMDAR : RAM : [ 6,00 GB ] EMI : [0B] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6,00 GB ] EMI : [0C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6,00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512,00 KB ] DRAM: 0x200000000 [ 8,00 GB ] UFS: CE014B4D3842383030314A4D2D424330 UFS: VEN : 0x01CE VID : KM8B8001JM-BC0 IFW : 0600 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0x3B96000000 [ 238,34 GB ] FSN : 00330036003400330034006100360064 REG : 0x101010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A79E35492488070F7020922E6AA8A35 DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-05-05 Product Manfct : OPPO Build Time : 26.04.2020 Product Brand : OPPO Product Model : CPH1945 Product Info : CPH1945 Product Name : CPH1945 Product Device : OP4B65 SW OTA Version : CPH1945PUEX_11.A.23_0230_202004270300 Display ID : CPH1945EX_11_A.23 Display ID : CPH1945EX_11_A.23_200427 Kernel Info : 4.9.117 STORAGE : LifeStatus : UFS : OK! Done! Elapsed: 00:00:44 |
The Following 4 Users Say Thank You to idrissou mohama For This Useful Post: |
![]() | #11 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2009
Member: 1043909 Status: Offline Thanks Meter: 56,554 | Quote:
Drivers must be installed before make any operation ! | |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
