Old 04-27-2019, 22:00   #1 (permalink)
ponix's Avatar
Member: 229016
Sonork: 100.1590620
Thanks Meter: 130
repair imei doogee x70
hi to all
i try to repair imei but not success
repair imei mode CM2
Operation : Repair Security [ v1.58 ]
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 150100523832314D42008699FA3F122B
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM128
[eMMC] : FLASH_CID : 150100523832314D42008699FA3F122B
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0x46860C5692C4C71AD1B8C2A4D141ACE5
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Error on Security Repair , Code : 0x2
Make sure about mobile is working and alive!
Check BaseBand state also, fix if need!
Operation Failed
Elapsed: 00:00:17
Reconnect Power/Cable!
repair imei mode AT
Wait for phone...
Phone found! [ 12 ]
Sync...
Init Ok, waiting for phone ...
Reading initial info, wait...
Phone Info :
BB : AT+EGMR=0,0
HW : AT+EGMR=0,4
SW : AT+EGMR=0,3
MM : AT+EGMR=0,1
VR : AT+EGMR=0,2
SN : AT+EGMR=0,5
Security Info :
IMEI [1] : AT+EGMR=0,7
IMEI [2] : AT+EGMR=0,10
IMEI [3] : AT+EGMR=0,11
IMEI [4] : AT+EGMR=0,12
Read Ok!
Update IMEI[1] to : 353535353535352 failed , record not exist or NVRAM damaged!
Update IMEI[2] to : 353535353535352 failed , record not exist or NVRAM damaged!
Done!
Elapsed: 00:01:10
what i do please ?
Old 04-28-2019, 13:04   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Make sure BB is alive in settings.
You can use MT2 module, it uses direct mode reapir, if NVRAM inside is alive.
Page generated in 0.15901 seconds with 8 queries
