Old 03-13-2016, 14:18   #1 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
Thumbs up neeed help regarding xolo a500s ips dead after flash
phone is on with virus ...below is read info log and after write flash log phone dead not know where is problem phone is on before flashing ..ther is some problem with pmt update as log says ..not full earse the phone yet ..
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164048601A3AA82B09F
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048601A3AA82B09F
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 072164E4A91A3FC1B5BEBF9AD3BE08AF
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : XOLO
ProdName : A500S_IPS
ProdModel : A500S_IPS
Device : A500S_IPS
AndroidVer: 4.2.2
MTKxCPU : MT6572
MTKxPRJ : ALPS.JB3.MP.V1
SECURITY :
IMEI_SW [1] : 911350
IMEI_SW [2] : 911350
BTMAC Addr : 88A73C337F05
WiFi MAC : 88A73CAB5C77
EXTRA :
LCD [0] : hx8379a_dsi_vdo_azet_ips
LCD [1] : ili9806c_dsi_vdo_djn
LCD [2] : ili9806c_dsi_vdo_qj
LCD [3] : otm8018b_dsi_vdo_trust
LCD [4] : otm8018b_dsi_vdo_djn
LCD [5] : ili9806c_dsi_vdo_txd
LCD [6] : ili9806c_dsi_vdo_azet_ips
LCD Res : 800x480
TOUCH [0] : ft5206
TOUCH [1] : msg2133
CAM [0] : s5k5eayx_yuv
CAM [1] : gc2035_yuv
CAM [2] : gc0329_yuv
MODEM : d208_c1a_hspa_gemini
LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR hdpi
Done!
Elapsed: 00:00:13
Reconnect Power/Cable!
Finish at : [3/13/2016 / 5:46:47 PM]
Start at : [3/13/2016 / 5:47:02 PM]
Operation : Flash [ v1.43 ]
======= Flash
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : d208_lava_ips , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3638 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000100000
Erase : 0x0000000002300000-0x0000000094840000
Flash Pre-Erase Done, time used : 00:00:22
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_d208_lava_ips.bin
Preloader Sent , Init passed
PartCount : 0013
Update PMT by user request
Repartition Failed! Break! Something wrong with HW or BL (FirmWare)
Old 03-13-2016, 14:50   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Full erase and then flash.
Br.
Infinity Box Support Team.
Old 03-13-2016, 16:41   #3 (permalink)
Member: 2340137
Try flash tool
Sent from my ASUS_Z00LD using Tapatalk
Old 03-13-2016, 17:22   #4 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand : XOLO
Device : A500S_IPS
AndroidVer: 4.2.2
MTKxCPU : MT6572
SECURITY :
EXTRA :
LCD Res : 800x480
TOUCH [0] : ft5206
TOUCH [1] : msg2133
Done!
Elapsed: 00:00:13
======= Flash
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
PartCount : 0013
Please make eMMC HW test,
i think it's Read only state or bad eMMC.
Old 03-14-2016, 08:34   #5 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Br.
check with full erase same error..
@ pls develpor of the infinty cm2 pls impliment the feature that we can know before flashing that emmc is in read only state so that set may not dead after flashing ..
Old 03-14-2016, 09:17   #6 (permalink)
Member: 459784
Sonork: +91-9179403087
Thanks Meter: 1,543
Hello,
Before Flash Did You Check Your Phone Verison From Setting-Abort? If No MayBe You Flashed With Wrong Ver - BTW - Post Here Memocy Test Info And Phone Back Sticker Pic!
Old 03-14-2016, 09:43   #7 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
Originally Posted by pradeep_kus View Post
Hello,
i have make read full info with cm2 its log is in my first post ..
at back sticker there is written
model a500s ips
w1514
sn;a500sips114d093113
Old 03-14-2016, 10:53   #8 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
It die at any case after day/hour/week or any other access attempt. Not see reason for that.
Page generated in 0.20432 seconds with 8 queries
