Request, InfinityBox CM2MTK manuel hi, I'm new CM2 user and i need manuel for mtk infinity :confused: reagrds |
1. Look at "Doc" folder in CM2 software folder 2. More info can be found here - Infinity-Box - Support |
Docs folder found in SPD but not in MTK Sent from my iPhone using Tapatalk |
Using CM2MTK is very simple. Just need to take care of few points- - Select correct CPU under Settings tab - Connect phone without pressing any key for all operation. - For Nand flash need to make read info first before any operation. - To read Nand FF (Factory Firmware) just check on Nand Extra box. For rest info just move the mouse pointer on required button and it will display it's work. CM2 is one of the simplest and easy tool here in gsm industry right now. Br. |
Request, InfinityBox CM2MTK manuel I have some questions pleas, How to select correct cpu? If possible explain the most important info when check phone info? Its necessary read flash before any operation? Its possible to read flash from phone and writ in other phone with some info? And what the most need take care to flash any mtk cpu? Thank you Regards Sent from my iPhone using Tapatalk |
1. For first time - enough bruteforce , for example. Also - SP and FP phone can be divided by a first look. 2. No, until SW will not ask about it. If it ASK mae it BEFORE operation - then you have a chance to take it before execute operation. There is just one - Smart AV. 3. Possible read dump ( long and useless ) and Factory FW as well. |
