12-20-2008, 20:22 | #1 (permalink) |
Junior Member Join Date: Sep 2007
Member: 578626 Status: Offline Thanks Meter: 7 | Revive LG KG270 done by Infinity COM7 [VCP0] selected module v1.58 Device: LG-KG270 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 230400 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL KG270 P16 ESA V10h XXX-XX Jun 11 2007 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20081221-000110.B1E.bin loading data... data loaded imei: 35744501559335900 reading eeprom-security_35744501559335900... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35744501559335900_20081221-000111.B1E.bin reading eeprom-complete_35744501559335900... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35744501559335900_20081221-000114.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Write Done Finished, time used: 250 sec Remove/Install battery now ! Loadng data, wait... Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Action: imei software version: KG270P16-ESA-V10b-XXX-XX-APR 17 2007+0 original imei: 35744501559335900 new imei: 35744501559335 imei verification Ok Done Finished ==== log: [12/21/2008 12:06:26 AM] ==== COM7 [VCP0] selected module v1.58 Device: LG-KG270 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 230400 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL KG270 P16 ESA V10b XXX-XX Apr 17 2007 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20081221-000640.B1E.bin loading data... data loaded imei: 35744501559335900 reading eeprom-security_35744501559335900... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35744501559335900_20081221-000640.B1E.bin reading eeprom-complete_35744501559335900... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35744501559335900_20081221-000643.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 00000000 code: 0000000000000000 Finished, time used: 14 sec Remove/Install battery now ! Thanks to Infinity Team |
The Following 2 Users Say Thank You to dj69 For This Useful Post: |
12-20-2008, 22:35 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
Lg b2060 flash done by infinity. | debmobile | Infinity-Box | 4 | 04-18-2011 07:53 |
Lg Kg245 Kiled by Infinity-Box Revived by | KhalIman | Infinity-Box | 24 | 01-09-2009 15:50 |
LG KP100 Unlock Done By Infinity | Chennairam | Infinity-Box | 4 | 10-20-2008 16:20 |
LG KP130 unlocked done by infinity | kingskie | Infinity-Box | 13 | 10-19-2008 19:26 |
Lg Kg275 Done By Infinity...............100% | /ARIF/ | Various | 1 | 12-26-2007 01:42 |
