01-01-2017, 11:10 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | redmi 2014912 give error in removing mi account Card found : 94FBD840 , v0134 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.08 Operation : Reset Settings [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 13A6B7D6 ID_BLOCK_I : 007050E1 ID_BLOCK_L : D3154FB7268CB9B493C80815D2A92921 ID_BLOCK_L : 7D10BE11028D3DB64BAAEF242EC1DFFC Use CM2 Internal Loader Error : Loader send failed! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 13A6B7D6 ID_BLOCK_I : 007050E1 ID_BLOCK_L : D3154FB7268CB9B493C80815D2A92921 ID_BLOCK_L : 7D10BE11028D3DB64BAAEF242EC1DFFC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Minor Error! Skip! Minor Error! Skip! Done! Elapsed: 00:00:24 Reconnect Power/Cable! what is this problem ? |
01-01-2017, 12:11 | #4 (permalink) |
Member: 2298369 Status: Offline Thanks Meter: 440 | here is readed frimware link- http://www.4shared.com/rar/i36VALXDb...l?in.uc123.com |
