Old 04-29-2011, 14:52   #1 (permalink)
MTK CHIP's Avatar
Member: 1248595
Sonork: 100.1607313
Thanks Meter: 99
Help needed for G'five BT01
Hello,
Here is the Log of the operation.
COM18 [VCP0] selected
module v3.30
Device: Autodetect 6253 NOR
Checking data, wait...
Action: reset settings ("format ffs") NAND
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6253:8A02:8A00
status: FF
bbchip bl ver: FE
NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C
chip size: 16Mb
otp status/size: S_DA_NOR_OTP_EXIST/00020000
NAND flash chip: not installed
internal RAM size: 00020000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (115200)...
done
ram test...
testing 32bit...
32bit ram test passed
testing 16bit...
16bit ram test passed
ram test passed
===> detect existing firmware structure...
detect ffs...
detect sec ro...
detect custom parameters...
detect project-id...
detect NOR info...
number of areas/bytes to read: 1:00040000
reading (HW_STORAGE_NOR)...
error: can not read memory: 0FAA:S_FT_READBACK_FAIL
can not read memory, errorcode: 0FAA
it may be problem with current operation
error: last error: 0FAA:S_FT_READBACK_FAIL
Disconnect...
done
Finished, time used: 1 min 4 sec
Remove/Install battery now !
phone come to stuck on logo. Now phone is dead
Taken action -
First try to ffs with Autodetected 6205-6239 NOR mode
but is show
module v3.30
Device: Autodetect 6205-6239 NOR
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6253:8A02:8A00]...
CPU: MT6253
high speed boot On
chip: 0000:0000:000F
status: FF
Select another CPU type [6253] and try again !
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 16 sec
Old 04-29-2011, 15:02   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Try to read detailed info and then flash the phone with same version.
Wr.
Old 04-29-2011, 15:16   #3 (permalink)
MTK CHIP's Avatar
Member: 1248595
Sonork: 100.1607313
Thanks Meter: 99
Wr.
Read detailed info...
module v3.30
advanced flash detection disabled
Action: read/check information
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6253
high speed boot On
status: FF
boot packet size: 0400
Boot Fail
Finished, time used: 11 sec
Read firmware
module v3.30
Action: read firmware NAND
Connect...
Connecting...
Booting...
CPU: 6253:8A02:8A00
status: FF
bbchip bl ver: FE
chip size: 16Mb
done
done
ram test...
testing 32bit...
testing 16bit...
ram test passed
detect ffs...
detect sec ro...
detect NOR info...
Disconnect...
done
Finished, time used: 1 min 38 sec
Old 04-29-2011, 22:05   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
which cable/box do you use as interface?
Old 04-30-2011, 07:54   #5 (permalink)
MTK CHIP's Avatar
Member: 1248595
Sonork: 100.1607313
Thanks Meter: 99
I use Infinity as Interface. and i use manually cable (3 point soldering cable Rx/Tx/Gnd)for connecting.
Old 04-30-2011, 15:03   #6 (permalink)
MTK CHIP's Avatar
Member: 1248595
Sonork: 100.1607313
Thanks Meter: 99
Infinity team need ur reply ASAP.
Old 04-30-2011, 22:07   #7 (permalink)
Member: 148515
hello!
i have no idea what could be reason for this.
Try to slightly heat CPU and Flash IC
Old 05-02-2011, 08:42   #8 (permalink)
MTK CHIP's Avatar
Member: 1248595
Sonork: 100.1607313
Thanks Meter: 99
hello!
Problem is not in hardware bro.
I solve the problem using Autodetected 6205-6239 NAND mode.
Here is the successful FFS log & Readed full flash.
module v3.30
Device: Autodetect 6228-6268 NAND
Connect...
Connecting...
Booting...
CPU: 6253:8A02:8A00
status: FF
bbchip bl ver: FE
chip size: 16Mb
done
Set baudrate (460800)...
done
ram test...
testing 32bit...
testing 16bit...
ram test passed
detect ffs...
ffs offset/size: 00000000/00000000
detect sec ro...
project-id: L5AMM07.9.52.1.3T05M1126_M700
detect NOR info...
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: JWT_Z900B_002_PCB01_GPRS_MT6253_S00.L5AMM07_9_52_1 _3T05M1126_M700.BIN
project-id: L5AMM07.9.52.1.3T05M1126_M700, 00000000
code offset: 00000000
ffs offset/size [02]: 00E00000/00200000
rom info structure: [standard] type (07)
TCL-ID is absent
===> done
New firmware found (v.3.30, database date: 26.04.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
area size: 14Mb
number of areas/bytes to read: 1:00E00000
file saved: C:\Documents and Settings\Administrator\Desktop\JWT_Z900B_002_PCB01 _GPRS_MT6253_S00.L5AMM07_9_52_1_3T05M1126_M700__fi rmware_20110502-130446.B0M.bin
Disconnect...
done
Finished, time used: 11 min 20 sec
NEW FIRMWARE UPLOADED ON RAPIDSHARE-
https://rapidshare.com/files/4602009...130446.B0M.bin
(Download this file from here i don't send this link to [email protected])
The Following User Says Thank You to MTK CHIP For This Useful Post:
Old 05-02-2011, 11:33   #9 (permalink)
Member: 1043909
Thanks Meter: 60,926
As I can understand it's a backup from damaged phone.
Or it is strated to work correctly after format FFS?
Old 05-02-2011, 12:15   #10 (permalink)
MTK CHIP's Avatar
Member: 1248595
Sonork: 100.1607313
Thanks Meter: 99
Yes u r right.
After power on the set after 1 hour set goes to dead automatically.
now i heat the phone CPU & flash IC. (may be it work good)
Post result ASAP.
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.20787 seconds with 9 queries
