s621 unlock problem i flash some flash file but cant continue
always error
i try to flash again with the backup its continue flashing
but phone cant power on
i try to format with complete mode
i can get this error Code:
COM6 [VCP0] selected
module v3.44
Device: Alcatel-S621X, S621A
Checking data, wait...
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
chip: 0001:5603:A006
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22442200:FFFFFF00000000
flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
ffs/eeprom address can not be detected, value from database assigned: 01020000/00FE0000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 35198902010835
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
error: wrong erase first sector at 0x01020000
error: format ffs failed
Finalization Fail
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S621X,S621A__system_log_20100626-165753.B0X.bin
Finished, time used: 28 sec
Remove/Install battery now !
any body can help me |
