07-02-2009, 15:48 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Muzaffarabad
Member: 695543 Status: Offline Sonork: 100.1602536 Thanks Meter: 149 | S621x check this problem please COM5 [VCP1] selected module v2.79 Device: Alcatel-S621X, S621A Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:6D03:A001 status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22422200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 35199002146867 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Area: Firmware flash: 01227E22422200:FFFFFF00000000 Write: Firmware error: error# 000000FF error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 error: wrong answer: 3B error: flash write error: 00000000:00002000 error: wrong answer: 74 error: flash write error: 00000000:00002000 error: wrong answer: DB error: flash write error: 00000000:00002000 error: wrong answer: 3B error: flash write error: 00000000:00002000 error: wrong answer: DB error: flash write error: 00000000:00002000 error: wrong answer: DB error: flash write error: 00000000:00002000 error: wrong answer: 3B error: flash write error: 00000000:00002000 error: wrong answer: DB error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 |
07-03-2009, 07:22 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Before what was set condition it was locked/OK? or Dead this problem comes when u r using pinfinder/battery r not charged/cable problem use power meter instead of battery if problem is solved by this procedure check HW Resold/change Flash chip BR UMER |
The Following User Says Thank You to maplegsm For This Useful Post: |
N96 check this problem | the jinnah | Nokia Base Band 5 ( BB-5 ) | 4 | 07-03-2009 16:23 |
Can you check this problem with Alcatel C630 flexing, please ? | doctormike | Multi-Box | 3 | 10-11-2007 04:21 |
