Check logs Code:
Log First time
Please, read more details about PinFinder:
www.infinity-box.com or www.infinity-box.biz
==== log opened: [28/08/2009 17:40:39] ====
Application: C:\Archivos de programa\InfinityBox\PinFinder\PinFinder.exe
Initializing...
software version: 1.19
Smart-Card S/N: XXXX
Smart-Card firmware version: 0112
Initializing PinFinder...
Initializing database...
base database version: 01
user database version: 01
Loading configuration...
Initializing cable list...
Initializing platforms...
Initialization finished
searching adapter at COM35...
adapter found, version: 2000
S/N: XXXXXXXXXXXXXXXXXXXXXXXXXXXX
done
Initializing...
done
Log after
==== log opened: [28/08/2009 19:11:40] ====
Initializing...
too many retries
can't find adapter
too many retries
can't find adapter
too many retries
done
too many retries
can't find adapter
too many retries
can't find adapter
too many retries
done
too many retries
can't find adapter
too many retries
can't find adapter
too many retries
done Log infinity
==== log: [28/08/2009 18:30:41] ====
COM35 [VCP0] selected
module v2.85
Device: ZTE-X760
Checking data, wait...
Action: read NOR flash
Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:4803:0001
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22312200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb
Initialize Done
Set baud ...
921600
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device rom info...
detection phase #1...
detect device rom info finished
rom info structure: 2nd [enhanced] generation
startup code area #1 is Ok
startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.8F230328.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z11_S_A07A106.BI N_40182282].rpl
rom info detection finished
device-id: 8F230328
rom info protocol ver: 04
ver. sw 1: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z11_S_A07A106.BIN
ver. sw 2: X760_Z11_S_A07A106, 7DDDE7BF
ffs offset/size: 00E00000/00200000
ffs address assigned: 00E00000
detect device sec info...
detect device sec info finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z11_S_A07A106__fullflash_part_1_of_1...
file saved: C:\Archivos de programa\InfinityBox\MModule\ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z11_S_A07A106__fullflash_part_1_of_1 _20090828-184138.B0X.bin
file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z11_S_A07A106__syste m_log_8F230328_40182282_20090828-184841.B0X.bin
Finished, time used: 1077 sec
Remove/Install battery now !
WARNING ! Settings will be cleared, user data erased, XXXX set to default value !
Make flash backup before this procedure !
Do you want to continue ?
operation aborted
==== log: [28/08/2009 18:49:02] ====
module v2.85
Action: reset settings
Model: ZTE-X760
19200 autodetect
CPU: MT6225
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: X760_Z11_S_A07A106
Version: ZTEMT25_07A_HW_A
44 byte(s) read
XXXX: 35235302962895
connection Ok
building list...
done
items to clear: 163
warning: wrong packet cs
items cleared: 163 of 163
building list...
done
items remains: 0
Finished, time used: 38 sec
==== log: [28/08/2009 18:54:21] ====
module v2.85
Action: unlock
unlock method: smart fast
Model: ZTE-X760
19200 autodetect
CPU: MT6225
status: FF
Date: 2006.06.14
Version: 1.0
44 byte(s) read
XXXX: 13579024681122
warning: current phone XXXX is incorrect !
It's need to repair XXXX for correct phone functionality !
connection Ok
157 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
145 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 52 sec
Action: XXXX
Model: ZTE-X760
Phone should be Switched ON !
Connecting, wait...
Hardware version: MT6225, E05
Hardware version: ZTEMT25_07A_HW_A
Software version: X760_Z11_S_A07A106"
Software date: 2006.06.14
Barcode: MT012345678901234567
XXXX write method: mode-1
XXXX write channel: XXXX #1 for dual sim/mono CPU
new XXXX: 352353029628952
verification failed
operation failed !
Finished, time used: 94 sec
Power off phone now !
XXXX 35235302962895 already was repaired: 28/08/2009-18:59:20
Continue with this XXXX ?
Action: XXXX
Model: ZTE-X760
Connecting, wait...
baud set to: 19200
error: connection failed !
operation failed !
Finished, time used: 82 sec
XXXX 35235302962895 already was repaired: 28/08/2009-19:01:39
Action: XXXX
Model: ZTE-X760
Connecting, wait...
baud set to: 19200
operation failed !
XXXX 35235302962895 already was repaired: 28/08/2009-19:06:46
Action: XXXX
Model: ZTE-X760
Connecting, wait...
baud set to: 19200
operation failed !
Finished, time used: 84 sec
XXXX 35235302962895 already was repaired: 28/08/2009-19:08:14
Action: XXXX
Model: ZTE-X760
Connecting, wait...
baud set to: 19200
operation failed !
Finished, time used: 79 sec
XXXX 35235302962895 already was repaired: 28/08/2009-19:09:46
Action: XXXX
Model: ZTE-X760
Connecting, wait...
baud set to: 460800
operation failed ! HERE i press stop
Finished, time used: 22 sec
Power off phone now
Pinfinder dead after that |
