Old 03-30-2009, 08:24   #1 (permalink)
Member: 696126
Thanks Meter: 63
sagem my220v unlock done...
COM4 [VCP0] selected
module v1.60
Device: Sagem-my220v
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
loading...
middle part...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: 8 EBI_IO_101207_1704 EBI_IO 101207_1704 Thhmm Dddmmmyyyy 0123
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-static_20090330-134554.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-security_20090330-134556.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20090330-134601.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_lock-area_20090330-134626.B1E.bin
backup critical area Done
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 80 sec
Remove/Install battery now !
The Following 2 Users Say Thank You to bbaj For This Useful Post:
Old 03-30-2009, 11:36   #2 (permalink)
Member: 130995
Thanks Meter: 35,229
module v1.60
Action: unlock
unlock method-1
Boot ...
loading...
middle part...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
Old 05-19-2009, 08:06   #3 (permalink)
KUMARANSUGUMAR's Avatar
Member: 726340
Sonork: 100.1624264
Thanks Meter: 86
another sagem my 220v unlock successful via infinity
COM3 [VCP0] selected
module v1.65
Action: unlock
unlock method-1
Boot ...
e-gold: 820010
loading...
middle part...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: 253 EBI_IH EBI_IH_170707_1253 Thhmm Dddmmmyyyy 0123456789ABCDEF
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-static_20090519-121213.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-security_20090519-121213.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20090519-121214.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220v_lock-area_20090519-121220.B1E.bin
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 30 sec
thank u infinity team
The Following User Says Thank You to KUMARANSUGUMAR For This Useful Post:
Old 05-19-2009, 08:13   #4 (permalink)
Member: 726340
Sonork: 100.1624264
Thanks Meter: 86
another successful unlock for my 220v via inifinity
module v1.65
Action: unlock
unlock method-1
Boot ...
e-gold: 820010
loading...
middle part...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Old 06-02-2009, 05:08   #5 (permalink)
Member: 615701
Thanks Meter: 9
My220V unlock successful with microbox !
READING IMEI: OK!
READING EEPROM: OK!
SAVING EEPROM: OK!
EEP_MY220V_35573************_2009_06_02_10_50_22.M BF
READING DATA: OK! PHONE ALLREADY UNLOCKED!
SAGEM MY220V UNLOCK: END!
After unlock you must unlock with 0000 on hand !
Old 06-27-2013, 16:57   #6 (permalink)
Member: 801830
Thanks Meter: 22
can u please post photo for pinout coz i tried alot of times and failed
Old 06-27-2013, 20:11   #7 (permalink)
Member: 1043909
Thanks Meter: 60,861
keyboard down: Sagem, Vodafone
1..........16
1: Gnd (RJ45 pin-8 or pin-7)
9: box Rx/phone Tx/PinFinder Rx (RJ45 pin-3)
10: box Tx/phone Rx/PinFinder Tx (RJ45 pin-2)
16: Gnd (RJ45 pin-8 or pin-7)
Help for SAGEM my220V unlocking code ffelix Phone Unlocking Codes & Maps 0 04-23-2008 09:35
Sagem my220V unlocked successfully yassyass Infinity-Box 1 04-16-2008 19:38
Sagem My220v Unlock Success jhepoy_org FuriousGold 1 04-04-2008 13:20
sagem my220v unlock dindou78 SAGEM JTAG UNLOCKER 18 03-07-2008 17:53
Page generated in 0.19545 seconds with 9 queries
