04-15-2011, 23:23 | #1 (permalink) |
No Life Poster Join Date: Sep 2008
Member: 868940 Status: Offline Thanks Meter: 90 | Zte n281 unlock problem COM3 [VCP0] selected module v3.82 Device: ZTE-N281 Checking data, wait... Action: write flash NAND write: Firmware ZTE-G-N281_ZTENJ35_OG_09A_PCB01_GPRS_MT6235B_S01.ORANGE_ ENG_EN_P107A3V1_0_4B05_2010-01-08_En_Fr_Es.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: ZTENJ35_OG_09A_BOOTLOADER_V005_MT6235B_ORANGE_ENG_ EN_P107A3V1_0_ nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/01C00000 firmware size: 32Mb ffs size: 28Mb detect sec ro... detect custom parameters... detect project-id... project-id: ORANGE_ENG_EN_P107A3V1.0.4B05 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: ZTENJ35_OG_09A_BOOTLOADER_V005_MT6235B_ORANGE_ENG_ EN_P107A3V1_0_ nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ZTENJ35_OG_09A_PCB01_GPRS_MT6235B_S01.ORANGE_ENG_E N_P107A3V1_0_4B05.BIN project-id: ORANGE_ENG_EN_P107A3V1.0.4B05, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/01C00000 rom info structure: [standard] type (07) TCL-ID is absent ===> done nfi area detection... bootloader version: ZTENJ35_OG_09A_BOOTLOADER_V005_MT6235B_ORANGE_ENG_ EN_P107A3V1_0_ nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Disconnect... done Finished, time used: 6 min 30 sec Remove/Install battery now ! pls....help is needed here br |
04-16-2011, 07:34 | #2 (permalink) |
Member: 868940 Status: Offline Thanks Meter: 90 | here is another flash process.... still white screen with boot up sound and switch off with sound.. bootloader version: ZTENJ35_OG_09A_BOOTLOADER_V005_MT6235B_ORANGE_ENG_ EN_P107A3V1_0_ nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/01C00000 firmware size: 32Mb ffs size: 28Mb detect sec ro... detect custom parameters... detect project-id... project-id: EB-BG-GLOBUL9-P107A3V1.0.2B01 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: ZTENJ35_OG_09A_BOOTLOADER_V005_MT6235B_ORANGE_ENG_ EN_P107A3V1_0_ nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ZTENJ35_09A_PCB01_GPRS_MT6235B_S01.EB-BG-GLOBUL9-P107A3V1_0_2B01.BIN project-id: EB-BG-GLOBUL9-P107A3V1.0.2B01, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/01C00000 rom info structure: [standard] type (07) TCL-ID is absent ===> done nfi area detection... bootloader version: ZTENJ35_OG_09A_BOOTLOADER_V005_MT6235B_ORANGE_ENG_ EN_P107A3V1_0_ nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done |
04-16-2011, 08:14 | #3 (permalink) | |
Freak Poster Join Date: Sep 2010 Location: I M FOLLOWING YOU
Member: 1398435 Status: Offline Sonork: 100.1664179 Thanks Meter: 172 | Quote:
Check file CDMA MOBLE ARENA | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
