01-30-2021, 23:40 | #20 (permalink) | |
No Life Poster Join Date: Dec 2012 Location: Goma, Democratic Rep. Congo
Member: 1859060 Status: Offline Sonork: 100.1651029 Thanks Meter: 170 | Can you please make scatter file firmware Quote:
Hi bro . Can you please upload scatter firmware dump for this device my phone is dead boot I need this file | |
01-31-2021, 03:45 | #21 (permalink) |
No Life Poster Join Date: Dec 2005 Location: malaysia Age: 41
Member: 205283 Status: Offline Thanks Meter: 80 | did you see persistent partition in memory tool?try delete it,samsung andriod 9,10 frp in persistent partition Sent from my iPhone using Tapatalk |
The Following User Says Thank You to siang8788 For This Useful Post: |
01-31-2021, 04:02 | #22 (permalink) | |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote:
Backup persistant and wipe it result? | |
The Following 2 Users Say Thank You to kamal_singla For This Useful Post: |
02-02-2021, 19:38 | #24 (permalink) | |
Junior Member Join Date: Jun 2008
Member: 798605 Status: Offline Sonork: underWATER Thanks Meter: 5 | Quote:
Erase it, | |
02-03-2021, 15:37 | #25 (permalink) |
Freak Poster Join Date: Sep 2017 Location: anywhere
Member: 2754769 Status: Offline Thanks Meter: 276 | Code: Card found : 1F877D05 , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Load IDBase v21168 Ok! Update configuration ... Socket Error # 11001 Host not found. Update failed! Check settings and/or internet connection! Operation : HW Report [ v2.21 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM292) MODE : BOOTROM PORT : 292 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : CD2041A6B211576D368699D304FE5A57 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 37B9D7AE9E0B0D385FC865609D6852F350A168731DFBA63EDA3974BFDA7C8FA7 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Boot done! Memory Info : CID : 150100515836334D4200E59FCC7C5761 MEM : VEN : SAMSUNG | OEM : 01 | DEV : QX63MB DAT : Size: 29820 MB, Max.Speed: 52000 kHz, blklen(512), nblks(61071360), ro(0) EXT_CSD Info : EXT_CSD rev. : v1.8 ( MMC v5.1 ) CSD struct rev. : v1.2 Supported command sets : 1h HPI features : 1h BG operations support : 1h BG operations status : 0h Correct prg. sectors : 0h 1st init time after part. : 3000 ms Min. write perf.(DDR,52MH,8b): 4bh Min. read perf. (DDR,52MH,8b): 0h TRIM timeout: 0 ms Secure feature support: 55h Secure erase timeout : 8100 ms Secure trim timeout : 5100 ms Access size : 3584 bytes HC erase unit size : 512 kbytes HC erase timeout : 300 ms HC write prot grp size: 8192 kbytes HC erase grp def. : 0h Reliable write sect count: 1h Sleep current (VCC) : 7h Sleep current (VCCQ): 7h Sleep/awake timeout : 26214400 ns Sector count : 3a3e000h Min. WR Perf. (52MH,8b): 4ch Min. Read Perf.(52MH,8b): 0h Min. WR Perf. (26MH,8b,52MH,4b): 47h Min. Read Perf.(26MH,8b,52MH,4b): 0h Min. WR Perf. (26MH,4b): 2bh Min. Read Perf.(26MH,4b): 0h Power class: 0 Power class(DDR,52MH,3.6V): 0h Power class(DDR,52MH,1.9V): 0h Power class(26MH,3.6V) : 0h Power class(52MH,3.6V) : 0h Power class(26MH,1.9V) : 0h Power class(52MH,1.9V) : 0h Part. switch timing : 2h Out-of-INTR busy timing: ah Card type : 57h Command set : 0h Command set rev.: 0h HS timing : 0h Bus width : 0h Erase memory content : 0h Partition config : 48h Boot partition size : 4096 kbytes Boot information : 7h Boot config protection: 0h Boot bus width : 2h Boot area write prot : 0h User area write prot : 0h FW configuration : 0h RPMB size : 16384 kbytes Write rel. setting : 1fh Write rel. parameter: 14h Start background ops : 0h Enable background ops: 2h H/W reset function : 1h HPI management : 0h Max. enhanced area size : 747h (15261696 kbytes) Part. support : 7h Part. attribute: 0h Part. setting : 0h General purpose 1 size : 0h (0 kbytes) General purpose 2 size : 0h (0 kbytes) General purpose 3 size : 0h (0 kbytes) General purpose 4 size : 0h (0 kbytes) Enh. user area size : 0h (0 kbytes) Enh. user area start: 0h Bad block mgmt mode: 0h Overall status : MLC status : 0% - 10% used SLC status : 0% - 10% used EOL status : Normal ( Less than 80% reserved blocks used ) Done! Elapsed: 00:01:15 Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM292) MODE : BOOTROM PORT : 292 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : CD2041A6B211576D368699D304FE5A57 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 37B9D7AE9E0B0D385FC865609D6852F350A168731DFBA63EDA3974BFDA7C8FA7 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Boot done! Done! Elapsed: 00:01:11 Reconnect Power/Cable! EMIBase : BAD or DAMAGED file selected! |
02-03-2021, 16:34 | #26 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | what is the file name ? also plz do not use iosFileUploader for this kind of tasks otherwise you got account locked automatically. iosFileUploader is for good working flash files. users who upload other files via iosFileUploader got account locked. |
02-03-2021, 19:00 | #27 (permalink) |
Freak Poster Join Date: Nov 2015
Member: 2489055 Status: Offline Thanks Meter: 71 | Samsung doesnot have frp partition Its persistent partition used for frp Some vendors use different name Like config |
The Following User Says Thank You to hardnsoft67 For This Useful Post: |
02-03-2021, 22:39 | #28 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
in EMI tab select preloader. | |
02-04-2021, 22:01 | #30 (permalink) | |
Member: 2754769 Status: Offline Thanks Meter: 276 | Quote:
