04-17-2009, 20:07 | #1 (permalink) |
Product Manager Join Date: Aug 2007 Location: Inside Java
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | Samsung B300 Succesfully Unlocked Device: C260 Phone must be powered-On Connecting... device found: B300BOHD3 phone connected, working... software version: B300BOHD3 Probably wrong model selected, Do you want to continue ? hardware revision: MP 0.600 hardware id: ےےےےےےےےےےےےےےےے imei: 3552490286924701 working... operaton finished Ok Finished, time used: 39 sec Remove/Install battery now ! Selected C260 with E210 Cable... When asked about wrong model selected, just click Yes.. Good Luck Phone Care Center Monrovia-Liberia |
The Following 7 Users Say Thank You to PhoneCareCenter For This Useful Post: |
04-18-2009, 19:51 | #2 (permalink) | |
Thanks a lot for test report ! We will add this model in list ASAP. | |
05-13-2009, 15:12 | #3 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: tunisia
Member: 898887 Status: Offline Sonork: ramazoti Thanks Meter: 210 | Quote:
Action: unlock Device: C260 Phone must be powered-On Connecting... device found: B300AFHG1 phone connected, working... software version: B300AFHG1 Probably wrong model selected, Do you want to continue ? hardware revision: MP 0.500 hardware id: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ imei: 3583980214166201 working... operaton finished Ok Finished, time used: 48 sec Remove/Install battery now ! | |
05-13-2009, 17:16 | #4 (permalink) |
No Life Poster Join Date: May 2008 Location: "I work for Good weekend"
Member: 765990 Status: Offline Sonork: 100.1582347 Thanks Meter: 207 | alls ok but problem about cabel...... can NS PRO cabel E210 can be used here??????????????..... waiting for answer.thanks in advance. |
05-13-2009, 22:54 | #6 (permalink) |
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | @ramazoti10 Model has been added : 21-04-2009: Samsung-B300 model supported "Samsung01" module v1.06 released: .B300 model supported .multilanguage user interface added @raja16sep Use UST Pro Cable or convert cable to UniBox Type RJ45 Pin2 is TX, RJ45 Pin3 is RX RJ45 Pin 7 & 8 are Ground..... Good Luck |
The Following User Says Thank You to PhoneCareCenter For This Useful Post: |
Samsung b259 succesfully unlock | sunnyarora | Infinity-Box | 3 | 06-24-2016 05:55 |
succesfully unlock i5700 with usb | LABOSSEF | NSPRO | 5 | 09-08-2010 07:15 |
Samsung j706 succesfully unlocked | m_mazhar_iqbal | UST Pro II | 2 | 11-16-2009 23:11 |
succesfully UNLOCK B300 with infinitybox not with ustpro2 | makkah mobile | UST Pro II | 0 | 08-27-2009 17:31 |
samsung B300 successfull unlock | mianjabbar | HWK | 5 | 02-25-2009 21:21 |
