Old 05-02-2009, 06:33   #1 (permalink)
Member: 575851
Thanks Meter: 544
B23DUO pin-out back-up flashfile and eeprom here
select modem myphone B23duo
this operation is unlock the phone but make back-up first in case the phone problem you make back-up fullflash firm
http://www.2shared.com/file/5588142/...1_of_1_2009050
http://www.2shared.com/file/5588148/...02-133926.html
COM8 [VCP0] selected
module v2.73
Device: MyPhone-B23
Checking data, wait...
Action: "sp-unlock"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
chip: 0001:6803:0000
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22202200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.5A87A 921.[X90_PCB01_GPRS_MT6225_S00.61503-PH-PR-V0_58.BIN_532104F1].rpl
New firmware detected (v.2.73, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send "system_log_..." file to support: [email protected]
- send flash backup files to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 5A87A921
identification#1 protocol ver: 04
ver. sw 1: X90_PCB01_GPRS_MT6225_S00.61503-PH-PR-V0_58.BIN
ver. sw 2: X90.61503-PH-PR-V0.58, 0EFBDEAC
ffs offset/size: 00E00000/001F0000
detect device identification#2...
detect device identification#2 finished
sim-lock status: unknown
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: MyPhone-B23_X90_PCB01_GPRS_MT6225_S00.61503-PH-PR-V0_58__ffs...
file saved: C:\Program Files\InfinityBox\MModule\MyPhone-B23_X90_PCB01_GPRS_MT6225_S00.61503-PH-PR-V0_58__ffs_20090502-134557.B0E.bin
Backup required data Done
Patch required data ...
detection procedure, wait...
detection procedure completed
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write: eeprom
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\MyPhone-B23_X90_PCB01_GPRS_MT6225_S00.61503-PH-PR-V0_58__system_log_5A87A921_532104F1_20090502-134902.B0X.bin
Finished, time used: 439 sec
Remove/Install battery now !
The Following 3 Users Say Thank You to ayhen42 For This Useful Post:
Old 08-27-2009, 08:55   #2 (permalink)
jr astigin's Avatar
Member: 757159
Thanks Meter: 467
can someone upload flashfile for b23 duo???????
TINNO25_GEMINI_PCB01_GPRS_MT6225_S00.E300-AM-PA77318_PR_R0_4_V6_PHILIPPINE.BIN
Old 08-27-2009, 11:15   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
You can download file from Infinity-Box support area:
MyPhone-B23_TINNO25_GEMINI_PCB01_GPRS_MT6225_S00.E300-AM-PA77318_PR_R0_4_V6_PHILIPPINE_En.B0M.bin
I need pin out schematic for 331 and 735 Helaman BF, BG, TH, BHx Series 4 05-24-2005 16:13
Backing up data and formatting N-Gage khandu WD2 & APE (Symbian Phones) 5 05-05-2005 23:42
Pin-Outs for Nokia 7160 and 252 Janu Nokia CDMA 6 01-11-2005 20:02
Back up & flashing eeprom with dejan 1.05??? watch man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 05-07-2002 07:36
Page generated in 0.17014 seconds with 9 queries
