09-24-2015, 14:01 | #1 (permalink) |
Junior Member Join Date: May 2015
Member: 2392427 Status: Offline Thanks Meter: 4 | Huawei G610-U20 Boot error Code: Operation : Check / Read Info [ v1.31 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 827 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending DA Ver : MTK_AllInOne_DA_v3.3001.00.00 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA start Failed at final stage! Check battery , cable , drivers and try try again Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! |
11-20-2015, 17:06 | #2 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Bangladesh Age: 40
Member: 1910629 Status: Offline Sonork: 100.1653190 Thanks Meter: 65 | same problem for me... i want to flash cm2 & sp flash tool boot after set auto on & boot error every time why i don,t understand set full on virous problem what i do ? |
11-20-2015, 18:25 | #3 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | G610-U20 Secured phones. Find the original signed FW and flash it. Best Regards, |
The Following User Says Thank You to DUNIYA JAMAL For This Useful Post: |
