03-05-2008, 11:29 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! as long as nobody able to help i can advice fast and easy method to detect needed pins: measure voltage on all pins and detect needed by voltage near 2,7-2,8volts. step by step tutroial is in out FAQ section under "second and tested way to find pinout" |
03-05-2008, 17:21 | #5 (permalink) | |
Registered User Join Date: Aug 2004 Age: 54
Member: 76533 Status: Offline Thanks Meter: 8 | Quote:
Thanks is the measure in the battery or without a battery | |
03-05-2008, 20:55 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please, measure voltahe with battery installed. Also here is detailed instruction for you: There are different "Chinese" phones with the same name but absolutely different hardware exist on market. Example: exist at least 30 "Chinese" phones with name "N95", at least 20 models "N73" etc. but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so it's impossible to give any advice about phone pinout only by phone name. So we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 Universal solution for pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en |
Samsung J750 Pin Out Cable | valoss | Easy-Unlocker | 1 | 06-26-2008 01:15 |
Samsung C160 Pin Out | cellbhai | UST Pro II | 1 | 02-21-2008 19:38 |
samsung E530 pin out | leroi | Trident/AGERE Platform | 3 | 08-01-2006 12:26 |
Samsung cable pin-out - tested | m.com | Samsung Flashers, Software, Firmware. | 5 | 02-23-2002 11:50 |
Samsung A100 pin-out | Elgravi | VLSI, Conexant, Skyworks and Old Models | 0 | 09-17-2001 14:17 |
