07-19-2021, 06:26 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Narowal
Member: 207708 Status: Offline Sonork: 100.1602241 Thanks Meter: 1,005 | Samsung Galaxy A10s FRP Bypass | A107F 2021 Patch | Samsung A10s Smart Reset By CM2MT Here are logs Its a Samsung A10s Phone and it is MTK base. All operation done in Flash Mode. Boot Key Vol+ + Vol- DA Link : https://www.4shared.com/rar/qZ7cktYe...RP_REMOVE.html Youtube link https://www.youtube.com/watch?v=ZRo74DIgsDo |
The Following 11 Users Say Thank You to umarnlw For This Useful Post: |
07-28-2021, 10:33 | #4 (permalink) |
No Life Poster Join Date: Nov 2004 Location: French 13 Age: 38
Member: 94762 Status: Offline Thanks Meter: 115 | you can show steps please not work for me with your files Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.27 Load IDBase v718267 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Preloader [HW DEV] Info : EMI : DEV : MT6765 EMI : SRC : preloader_s96116ca1.bin EMI : CNT : 0007 EMI : [00] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2,00 GB ] EMI : [01] : eMMC : DDR3 : ID : 700100464D42434541 : VEN : KINGSTON | DEV : FMBCEA : RAM : [ 2,00 GB ] EMI : [02] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3,00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100515836334D42 : VEN : SAMSUNG | DEV : QX63MB : RAM : [ 2,00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100515836334142 : VEN : SAMSUNG | DEV : QX63AB : RAM : [ 2,00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100475836424142 : VEN : SAMSUNG | DEV : GX6BAB : RAM : [ 3,00 GB ] EMI : [06] : eMMC : DDR3 : ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3,00 GB ] Operation : Reset Settings/Format FS [ v2.27 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM20) MODE : PRELOADER PORT PORT : 20 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : X_FireFly | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : CHANGE : v2112 AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port (COM20) MODE : BOOTROM PORT : 20 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 0720B3BC2C8BD165C50034556D46B3FD BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 69947CE4CC5ABAB33C39B97345F9D0B3CF8DB2A86B5BC6DB68 C1C805E06A81B7 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : X_FireFly | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : CHANGE : v2112 AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_s96116ca1.bin EMI : CNT : 0007 EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! |
07-28-2021, 20:40 | #5 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: John Kemeny1926-1992 Age: 57
Member: 136220 Status: Offline Thanks Meter: 403 | Quote:
DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Its a Samsung A10s Phone and it is MTK base. All operation done in Flash Mode. Boot Key Vol+ + Vol- DA Link : https://www.4shared.com/rar/qZ7cktYe...RP_REMOVE.html | |
07-28-2021, 21:11 | #6 (permalink) | |
Junior Member Join Date: Jan 2018
Member: 2802074 Status: Offline Thanks Meter: 0 | Quote:
hi, your link dont work | |
07-29-2021, 06:40 | #7 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Uzbekistan / Bukhara
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 622 | 1- select Infinity FireFly SmartPhone in Platform settings. 2- run memory tool and press init button 3- connect powered off phone in to pc 4- when MemoryTool init your device select PERSISTENT partition and wipe it . |
The Following User Says Thank You to UzUnlocker For This Useful Post: |
07-29-2021, 07:25 | #10 (permalink) | |
Banned Join Date: Feb 2012 Location: pakistan
Member: 1723223 Status: Offline Sonork: 100.1649485asad297 Thanks Meter: 30 | Quote:
07-29-2021, 09:44 | #11 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | https://www.4shared.com/rar/qZ7cktYe...RP_REMOVE.html ------------------ https://www.youtube.com/watch?v=ZRo74DIgsDo --------- |
07-29-2021, 23:58 | #12 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | So ...did anyone tested WITHOUT TP ? b.r Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
07-31-2021, 15:49 | #13 (permalink) |
Freak Poster Join Date: Oct 2014 Location: Pakistan
Member: 2276949 Status: Offline Thanks Meter: 160 | Yes Without TP Yes Without Test Point Without any Boot Key and Without any DA Simply Connect Power Off Phone and Do The Rest Code: Operation : Identify [ v2.27 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port_V1632 (COM37) MODE : BOOTROM PORT : 37 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 6EE8740DD566CA3CA14E20F2173F2DFB BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 8B4D47C894A8AD07D7FA15EFD5D6576FB546D88E84C1304BFB4A8273613F96B1 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Look for EMI BROM : SLA : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_s96116ca1.bin EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100514436334D4203A24F6A39862F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 2723113529 ( 0xA24F6A39) , MF : 8/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 7D699F14D07C15AA7F163DF5D52F336 DA : USB : HIGH-SPEED Boot done! Product Brand : samsung Product Model : SM-A107F Product Name : a10sxx Product Device : a10s Patch Level : QP1A.190711.020 Display ID : QP1A.190711.020.A107FXXU8BUF1 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-04-01 Build Time : 14.06.2021 Product Info : a10s Product Board : S96116CA1 Board Platform : mt6765 Product Manfct : samsung NVRAM check : Passed! NVRAM : SEC SIGNED [ IMEI RSA SIGNED ] Backup sensetive data [ 16 ] Backup path : Backup\MT6765__6EE8740DD566CA3CA14E20F2173F2DFB\ [5] Read : NVRAM [14] Read : NVDATA [23] Read : PROINFO [28] Read : LK [13] Read : NVCFG [16] Read : PROTECT1 [17] Read : PROTECT2 [1] Read : PGPT [19] Read : PERSIST [0] Read : PRELOADER [6] Read : EFS [7] Read : SEC_EFS [20] Read : PERSISTENT Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : NOT Enabled! PRELOADER : DEVICE : DEV : MT6765 NME : preloader_s96116ca1.bin CNT : 0008 EMI : [00] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 700100464D42434541 : VEN : KINGSTON | DEV : FMBCEA : RAM : [ 2.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100515836334D42 : VEN : SAMSUNG | DEV : QX63MB : RAM : [ 2.00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100515836334142 : VEN : SAMSUNG | DEV : QX63AB : RAM : [ 2.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100475836424142 : VEN : SAMSUNG | DEV : GX6BAB : RAM : [ 3.00 GB ] EMI : [06] : eMMC : DDR3 : ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 2.00 GB ] PRELOADER saved to : Backup\PRELOADER\preloader_s96116ca1.bin Done! Elapsed: 00:00:46 |
The Following 6 Users Say Thank You to Khan Bhaie For This Useful Post: |
10-08-2021, 03:32 | #14 (permalink) |
Insane Poster Join Date: Apr 2008 Location: vanderbijlpark
Member: 758363 Status: Offline Thanks Meter: 34 | 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM79) MODE : PRELOADER PORT PORT : 79 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port_V1632 (COM40) MODE : BOOTROM PORT : 40 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 91AAA93C807BF476DBC69D79F258A2D6 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : B785C3D32EE354F8D0D532AA4092D9975F34DF9AECD36D6DB8 41875845E63BA7 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: CID : 150100514436334D4203682790DEA601 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 1747423454 ( 0x682790DE) , MF : 10/2019 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0x747C00000 [ 29,12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B0610E03A47BF6B69C33BFFA6D577441 DA : USB : HIGH-SPEED Boot done! Product Brand : samsung Product Model : SM-A107F Product Name : a10sxx Product Device : a10s Patch Level : QP1A.190711.020 Display ID : QP1A.190711.020.A107FXXU7BTJ1 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-09-01 Build Time : 08.10.2020 Product Info : a10s Product Board : S96116CA1 Board Platform : mt6765 Product Manfct : samsung NVRAM : TITAN_S1_Q0MP1_K62V1_64_BSP_MDBIN_PCB01_MT6765_S00 .MOLY_LR12A_R3_TC10_PR1_SP_V4_P8 NVRAM : 0xBD0AD9BF NVRAM : State : Ok! NVRAM : SecLv : Vendor Signed INFO : WiFi MAC : CC464E689B2E INFO : BlTh MAC : CC464E689B2F INFO : IMEI[1] : 6D119E7E0511282 INFO : IMEI[2] : 8D761B46E3E29F5 STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : NOT Enabled! PRELOADER : DEVICE : DEV : MT6765 NME : preloader_s96116ca1.bin CNT : 0007 EMI : [00] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2,00 GB ] EMI : [01] : eMMC : DDR3 : ID : 700100464D42434541 : VEN : KINGSTON | DEV : FMBCEA : RAM : [ 2,00 GB ] EMI : [02] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3,00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100515836334D42 : VEN : SAMSUNG | DEV : QX63MB : RAM : [ 2,00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100515836334142 : VEN : SAMSUNG | DEV : QX63AB : RAM : [ 2,00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100475836424142 : VEN : SAMSUNG | DEV : GX6BAB : RAM : [ 3,00 GB ] EMI : [06] : eMMC : DDR3 : ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3,00 GB ] PRELOADER saved to : Backup\PRELOADER\preloader_s96116ca1.bin Done! Elapsed: 00:00:32 Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM79) MODE : PRELOADER PORT PORT : 79 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port_V1632 (COM40) MODE : BOOTROM PORT : 40 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 91AAA93C807BF476DBC69D79F258A2D6 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : B785C3D32EE354F8D0D532AA4092D9975F34DF9AECD36D6DB8 41875845E63BA7 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: CID : 150100514436334D4203682790DEA601 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 1747423454 ( 0x682790DE) , MF : 10/2019 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0x747C00000 [ 29,12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B0610E03A47BF6B69C33BFFA6D577441 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:31 Reconnect Power/Cable! NO NEED DA FILE |
10-08-2021, 03:32 | #15 (permalink) |
