gmt91050 | 10-28-2015 14:22 | SAMSUNG I9076 MT6572 Too much data! Break! Send report to support NEED SOLUTION Code:
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 90014A4834473164048600A3879321B3
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : d1G4
[eMMC] : FLASH_CID : 90014A4834473164048600A3879321B3
[eMMC] : FLASH_EXT : 00200000/00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Scanning FileSystem now , please wait
Scan Done, infected files found : 210
AVVerify : Too much data! Break! Send report to support
Error! Check previous message for more info!
Check battery, cable, charge! Before try again, check result!
Operation Failed
Elapsed: 00:00:40
Reconnect Power/Cable! http://s30.postimg.org/m81miwmjl/screenshot_18.png
IF THE TEAM NEED ITS BACKUP I CAN UPLOAD FOR FURTHER TEST |
