03-27-2017, 21:18 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Tabligbo
Member: 1032123 Status: Offline Sonork: akeal81 Thanks Meter: 29 | Tecno w3lte dead FIRSTLY THIS TECNO W3LTE COME WITH HANG ON LOGO I CONNECT IT TO INFINITY AND GET HIS BACKUP WITH THIS LOG Start at : [27/03/2017 / 14:15:26] Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D323237D305004217C5144F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D420005D34F14C317 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x0B26E5F83E8EAA119ABAC116A63BAF93 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : TECNO ProdName : TECNO-W3LTE ProdModel : TECNO-W3LTE Device : TECNO-W3LTE AndroidVer: 6.0 MTKxCPU : MT6735 MTKxPRJ : W3LTE-H356D1-M-161216V55 [Read Ok] : preloader_rlk6735m_65u_m0.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6737M / V1.1.2 / rlk6735m_65u_m0 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 3161 MiB Scatter saved to : F:\AT WORKING\MT6735__TECNO__TECNO-W3LTE__TECNO-W3LTE__6.0__W3LTE-H356D1-M-161216V55\ All done! Done! Elapsed: 00:07:40 Reconnect Power/Cable! Finish at : [27/03/2017 / 14:23:07] AND AFTER THIS I TRIED TO FORMAT BUT I GET THIS LOG Start at : [27/03/2017 / 14:48:56] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : NOT INSTALLED Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:24 Reconnect Power/Cable! Finish at : [27/03/2017 / 14:49:20] NOW THE PHONE NOT START UP IT DEAD PLEASE HELP ME URGENT |
03-28-2017, 06:49 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | It not just bad, there is some HW problem - eMMC connection between itself and CPU is damaged. |
03-28-2017, 08:31 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Seems as my explanation gives you no info, what mean you have no idea how deal with HW. Return set back. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
