08-29-2016, 12:37 | #1 (permalink) |
Freak Poster Join Date: Nov 2015 Location: Pakistan lahore
Member: 2482838 Status: Offline Sonork: 100.1676271 Thanks Meter: 442 | SAMSUNG NOTE 5 CLONe MT6580 FLASH FILE SAMSUNG NOTE 5 CLONe MT6580 IEMI REPAIR DONE FACTORY FIRMWARE READ DONE WITH CM2 TOOL Here is info Code: Card found : S/N : CEB0926E , v0132 Chinese Miracle II [MTK module] v 1.55 Operation : Check / Read Info [ v1.55 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 450100445331303038019CE14A5C1347 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 8001S [eMMC] : FLASH_CID : 450100445331303038019CE14A5C1347 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xB6E6A67CE7E9E6503D87DC68EE0623BF INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : samsung ProdName : nobleltezh ProdModel : SM-N9200 Device : nobleltehk AndroidVer: 5.1.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2.19_HCT6580.WEG.A.L_P20 Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Repair Security [ v1.55 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Init Service mode failed, something went wrong :( Reconnect Power/Cable! Operation : Repair Security [ v1.55 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 450100445331303038019CE14A5C1347 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 8001S [eMMC] : FLASH_CID : 450100445331303038019CE14A5C1347 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xB6E6A67CE7E9E6503D87DC68EE0623BF INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok Set IMEI [00] : 354321365765892 Set IMEI [01] : 352334154264870 Prepare finished. Security check required! Wait for phone... Phone found! [ 15 ] Sync... Repair done! Done! Elapsed: 00:01:18 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.55 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 450100445331303038019CE14A5C1347 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 8001S [eMMC] : FLASH_CID : 450100445331303038019CE14A5C1347 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xB6E6A67CE7E9E6503D87DC68EE0623BF INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... USBDL : Init HSUSB Ok! xGPT : Normalize settings Ok! Brand : samsung ProdName : nobleltezh ProdModel : SM-N9200 Device : nobleltehk AndroidVer: 5.1.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2.19_HCT6580.WEG.A.L_P20 [Read Ok] : preloader_hct6580_weg_a_l.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / hct6580_weg_a_l / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1397 MiB Scatter saved to : C:\Users\khizar\Desktop\MT6580__samsung__SM-N9200__nobleltehk__5.1.1__ALPS.L1.MP6.V2.19_HCT6580.WEG.A.L_P20\ All done! Done! Elapsed: 00:09:49 Reconnect Power/Cable! Br khizar.ali |
The Following 5 Users Say Thank You to khizar.ali For This Useful Post: |
