Samsung s7562 MTK 6575 Format Done but problem not solve Here the log file an other Samsung s7562 format done but phone problem not solve condition of phone is only Samsung logo and stop loading i have tried so many MTK phone like this same problem please Mr Dzirt do same thing to alive it customer take his phone to other shop and he return it alive and he told me it was fixed by Volcano box i really don't want to mentioned about Volcano box even i don't have it so please fix this issue for the upcoming update here is my log ================================================== ================================================== ======= Card found: S/N 680F:0128 Chinese Miracle II [MTK module] v 1.06 Operation : Check / Read Info [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 49 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x0F WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A1A2B243C045 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Format FileSystem [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 49 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x0F WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A1A2B243C045 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 0 Format : Cache and UserData (Full Factory Reset) Other : Set SpecFTM Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
Hello, there is no any miracle can be done, if installed different BOOT/SYSTEM image or something already damaged. Soon I add system integrity check, but still much to do for it. It helps repair some cases, but android mtk - is a big story with much variants. |
First of all i thank you that you have replayed me and then i well be waiting for that but if possible please do it as soon as possible thanks in advance .... |
