samsung s7582 mtk 7562 flash with wrong file now dead |
Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D42019242CCE3C01F DA Stat : v4.2 on BBID : 0x88 Configure emi settings Error : DA init Failed! Error code : 0x5 Boot Error! Operation Failed Elapsed: 00:00:17 Reconnect Power/Cable! plz help |
Chinese Miracle II [MTK module] v 1.17 User selected Preloader file : preloader_hexing72_wet_jb3.bin Operation : Init Preloader [ v1.17 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D42019242CCE3C01F DA Stat : v4.2 on BBID : 0x88 Configure emi settings Error : DA init Failed! Error code : 0x5 Boot Error! Operation Failed Elapsed: 00:00:21 Reconnect Power/Cable! User selected DumpFile , extracted : preloader_mbk72_wet_lca.bin Operation : Init Preloader [ v1.17 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D42019242CCE3C01F DA Stat : v4.2 on BBID : 0x88 Configure emi settings Error : DA init Failed! Error code : 0x5 Boot Error! Operation Failed Elapsed: 00:00:19 Reconnect Power/Cable! |
Better find similar phone, than try thousand of files. |
make a pic of phone back side and upload here i will give you firmware dump |
