07-12-2015, 09:46 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: india Age: 39
Member: 725038 Status: Offline Sonork: 100.1675584 Thanks Meter: 288 | spd 7731 not parton read spd 7731 perfect not work ----------------------------------------------- 1. Remove battery. Insert battery back 2. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_14B_TSHARK28_W14.50_Debug Project : sc7731g_CP0_modem HWInfo : sc7731g_CP0_modem Compile : 12-08-2014 14:17:31 Phone Security Info : IMEI [1] : 911437403040035 IMEI [2] : 911437403240031 BT_ADDR : 000000000000 Done Reconnect Power/Cable! Start at : [7/12/2015 / 1:53:53 PM] Operation : Read PatternLock [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 |7xSync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [7/12/2015 / 1:55:26 PM] Start at : [7/12/2015 / 1:55:55 PM] Operation : Read PatternLock [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Boot Files missing! Select SLDR or PAC file! Boot failed! Reconnect Power/Cable! Finish at : [7/12/2015 / 1:56:06 PM] Start at : [7/12/2015 / 1:56:28 PM] Operation : Read PatternLock [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 SOL Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [7/12/2015 / 1:57:07 PM] Start at : [7/12/2015 / 1:57:21 PM] Operation : Read PatternLock [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 .8Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable ========================= Start ========================= 7/12/2015 / 1:58:50 PM ================================================== ======= Card found: S/N 495B:0128 Chinese Miracle II [SPD module] v 1.02 Start at : [7/12/2015 / 2:01:40 PM] Operation : Read PatternLock [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Finish at : [7/12/2015 / 2:01:55 PM] Start at : [7/12/2015 / 2:03:07 PM] Operation : Read PatternLock [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Device boot not done Check Drivers Try again Reconnect Power/Cable! Finish at : [7/12/2015 / 2:04:31 PM] Start at : [7/12/2015 / 2:04:47 PM] Operation : Read PatternLock [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 ƒ7ÈSync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable ========================= Start ========================= 7/12/2015 / 2:12:02 PM ================================================== ======= Card found: S/N 495B:0128 Chinese Miracle II [SPD module] v 1.02 |
07-12-2015, 10:09 | #4 (permalink) |
Member: 725038 Status: Offline Sonork: 100.1675584 Thanks Meter: 288 | 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 ƒ7ÈSync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable ========================= Start ========== |
The Following User Says Thank You to tejas243404 For This Useful Post: |
07-12-2015, 10:13 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Again : Check Infinity - SPD ANDROID SC77xx Base Info.pdf manual for more info. Until you not understand what do and how - can't help in anything. You can try 1,100,1000,100000000 times. It change nothing. |
07-12-2015, 10:31 | #6 (permalink) | |
No Life Poster Join Date: Jul 2013 Location: uganda
Member: 1976974 Status: Offline Sonork: 100.1641825 Thanks Meter: 92 | Quote:
Where to find this " Infinity - SPD ANDROID SC77xx Base Info.pdf manual for more info " | |
