09-23-2014, 02:37 | #331 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: Mexicali
Member: 372188 Status: Offline Thanks Meter: 57 | Quote:
09-23-2014, 09:49 | #333 (permalink) | |
Product Supporter Join Date: Mar 2005 Location: in CPU
Member: 128745 Status: Offline Thanks Meter: 16,938 | Quote:
solution : try to enter 0000000 manualy in phone if not work then flash your phone to unbranded firmware and then retry unlock should be done 100% let me know result | |
09-23-2014, 11:50 | #334 (permalink) |
No Life Poster Join Date: Mar 2008 Location: hungphongmobile.vn
Member: 733209 Status: Offline Sonork: 1001620525 Thanks Meter: 426 | Samsung Note 3 SM-N900A UNLOCKED Model: SM-N900A HWID: CMB00FCC0B4FEA0 Imei: 3575720522xxxx Starting unlock process. Msladdress READED OK. Sending data to server. Sending Authorization to the phone. Phone authorized OK. Checking status of simlock. Simlock status: 00000001 Unlock Done. If phone ask for code, enter 00000000. Restarting phone. |
09-24-2014, 17:02 | #335 (permalink) |
Freak Poster Join Date: Oct 2010 Location: india
Member: 1417201 Status: Offline Sonork: 100.1626868 Thanks Meter: 32 | pls help for unlock n9005 i have error while unlocking i left one credit here is info Model: SM-N9005 HWID: CMB00CF7F55BEA0 Imei: 3575070---------- Starting unlock process. Msladdress READED OK. Sending data to server. Problem with MSL. Reboot the phone and aplication, and try again. i will try almost 20 times same results pls help |
09-24-2014, 18:44 | #336 (permalink) |
Freak Poster Join Date: May 2008 Location: morocco fes
Member: 782106 Status: Offline Thanks Meter: 8 | hi plz help me i lost 2 credit i lost 1 credit without open my account i had 10 credit i unlock 3 phone remained 7 credit date 20-09-2014 the day i open my account i found 6 credit i not know where he went 1 credit now i try unlock note 3 neo n7505 i lost 1 credit and the phone not unlock Model: SM-N7505 HWID: C1604C9 Imei: 35153906 Starting unlock process. Msladdress READED OK. Sending data to server. Sending Authorization to the phone. Phone authorized OK. Unlock Failed. Retry Again user dts45 |
09-24-2014, 18:56 | #337 (permalink) | |
Imei: 351539060662048 at 24/09/2014 15:59:41 Imei: 352123060571035 at 20/09/2014 15:36:54 Imei: 352123060911397 at 20/09/2014 16:02:31 Imei: 353748062808586 at 23/09/2014 15:35:18 Imei: 357518053589750 at 20/09/2014 15:35:07 | |
09-24-2014, 22:38 | #338 (permalink) |
Member: 782106 Status: Offline Thanks Meter: 8 | I NOT UNLOCK THIS IMEI Imei: 353748062808586 at 23/09/2014 15:35:18 CAN I CHANGE MY PASSWORD ?? |
The Following User Says Thank You to zakaria78 For This Useful Post: |
09-25-2014, 02:53 | #339 (permalink) |
Freak Poster Join Date: Aug 2005 Location: Kingston Age: 46
Member: 166442 Status: Offline Thanks Meter: 26 | Model: SM-N900T HWID: CMB00ECD04B7571 Imei: 35891xxxxxxxxx Starting unlock process. Msladdress READED OK. Sending data to server. Sending Authorization to the phone. Phone authorized OK. Checking status of simlock. Simlock status: 00000001 Unlock Done. If phone ask for code, enter 00000000. Restarting phone. unlock ok |
The Following User Says Thank You to kingsat100 For This Useful Post: |
09-25-2014, 04:13 | #340 (permalink) |
Freak Poster Join Date: Mar 2008 Location: kabul AFGHANISTAN Age: 35
Member: 724190 Status: Offline Sonork: zabih Thanks Meter: 16 | hello i unlock sam n900t unlock error plese cheak this eroor and retrun my credit user samsung187 [24/09/2014 03:14:28] Connecting... Connected to server Ok Requesting Info... Credits left : 5 [24/09/2014 03:15:03] Connecting... Connected to server Ok Requesting Info... Samsung Unlocker 1.06 Model selected : Samsung GSM Port selected : USB Serial Port (COM16) Using port COM16... Reading info... SW Version :N900TUVUBMI7 HW Version :REV0.6 PDA Version :N900TUVUBMI7 CSC Version :N900TTMBBMI7 Product Code :SM2N900TZWETMB Serial Number :RV8F10R2HJJ Connecting... Connected to server Ok Requesting Info... Auth 1... Error Auth MSLCode !!! rsp : AT+MSLSECUR=2,RV8F10R2HJ_51204E330F491D4B1D59431B1 2481B20 +MSLSECUR:2,NG_TOOMANY [24/09/2014 03:15:29] Connecting... Connected to server Ok Requesting Info... Credits left : 4 |
09-25-2014, 09:53 | #341 (permalink) | |
This is not log of DT Samsung client , please post in correct thread | |
09-25-2014, 10:25 | #343 (permalink) |
Freak Poster Join Date: Oct 2006 Location: India
Member: 376471 Status: Offline Sonork: 100.1608095 Thanks Meter: 107 | Model: SM-G900A HWID: CMA00575396F161 Imei: 35350206xxxxxx Starting unlock process. Msladdress READED OK. Sending data to server. Sending Authorization to the phone. Phone authorized OK. Checking status of simlock. Simlock status: 00000001 Unlock Done. If phone ask for code, enter 00000000. Restarting phone. |
The Following User Says Thank You to ashamsu For This Useful Post: |
09-25-2014, 16:57 | #344 (permalink) |
Junior Member Join Date: Mar 2007 Location: Burkina Faso
Member: 468971 Status: Offline Thanks Meter: 0 | login problem to samsung unlocker DT-Client Hi my friend, I'm not able to use the pass and the login you sent me to use the Samsung Unlocker DT-Client. When I try to use my pass and my login I got from you, i get these error message: 1_error checking the login, verify your firewall and internet connection. 2_ Check your user and password and try again;you might have no credits. I try different computer but I got the same message every time. Any solution? |
